August 8, 20195 yr comment_581460 1 hour ago, wal280z said: sometimes bush fixes become permanent Awesome. Glad to hear your bush is still fixed! Link to comment https://www.classiczcars.com/forums/topic/62552-78-280z-turns-off-with-turn-signalreverse-lights/?&page=9#findComment-581460 Share on other sites More sharing options...
August 8, 20195 yr comment_581464 @Usain_Boat Would you do me a favor and note quote in reverse background if possible. It's really hard for me to read it. You might be able to get a pencil torch if you can't get enough heat too it. When you hold an iron to it, hold it underneath. Remember heat rises and the wires will heat better on top of the iron Edited August 8, 20195 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/62552-78-280z-turns-off-with-turn-signalreverse-lights/?&page=9#findComment-581464 Share on other sites More sharing options...
August 8, 20195 yr Author comment_581468 Well it's definitely not the prettiest soldering job I've done but it's done and the car runs correctly! I also checked the other splices around it and they were solid but a little corroded so I just put some dialectric grease on them and taped it all back up. Link to comment https://www.classiczcars.com/forums/topic/62552-78-280z-turns-off-with-turn-signalreverse-lights/?&page=9#findComment-581468 Share on other sites More sharing options...
August 8, 20195 yr comment_581485 WOW a nice ending for a persistent trouble shooter. That was a very unusual problem to solve. My hat is off to you!!! Link to comment https://www.classiczcars.com/forums/topic/62552-78-280z-turns-off-with-turn-signalreverse-lights/?&page=9#findComment-581485 Share on other sites More sharing options...
August 8, 20195 yr comment_581486 Yes, kudos! Link to comment https://www.classiczcars.com/forums/topic/62552-78-280z-turns-off-with-turn-signalreverse-lights/?&page=9#findComment-581486 Share on other sites More sharing options...
