grannyknot Posted November 4, 2019 Share #25 Posted November 4, 2019 On 11/4/2019 at 2:19 AM, siteunseen said: I was about to go with a $300 stage 3 kit from Center Force. Expand I did go with the stage 3 Center Force unit and it was complete overkill, the stock clutch would have been more than adequate, I know now. 1 Link to comment Share on other sites More sharing options...
SoCalJim Posted November 4, 2019 Share #26 Posted November 4, 2019 The stock clutch kit through Amazon looks like a good deal! Link to comment Share on other sites More sharing options...
madkaw Posted November 4, 2019 Share #27 Posted November 4, 2019 With 3.90 gears I drive around town in third gear with my TEP lightened flywheel . That was with a 2.4 with a 490 cam. If your engine is strong with those gears you will be fine. 1 Link to comment Share on other sites More sharing options...
LeonV Posted November 4, 2019 Share #28 Posted November 4, 2019 On 11/4/2019 at 1:12 AM, SoCalJim said: Thanks Leon! I’m going to stop thinking! Expand On 11/4/2019 at 2:19 AM, siteunseen said: Leon V suggested the cheap stock oem clutch and pressure plate was fine, and it was/is. Exedy 6009 I think from amazon, $100. Works great. Thanks again @LeonV Saved me some $. I was about to go with a $300 stage 3 kit from Center Force. Expand ?? 1 Link to comment Share on other sites More sharing options...
Jeff G 78 Posted November 4, 2019 Share #29 Posted November 4, 2019 On 11/4/2019 at 2:19 AM, siteunseen said: Leon V suggested the cheap stock oem clutch and pressure plate was fine, and it was/is. Exedy 6009 I think from amazon, $100. Works great. Thanks again @LeonV Saved me some $. I was about to go with a $300 stage 3 kit from Center Force. Expand That's what I run in my racecar. It has worked great. Link to comment Share on other sites More sharing options...
chaseincats Posted November 6, 2019 Share #30 Posted November 6, 2019 (edited) How loud are these lightened flywheels? I've heard they make a noise similar to a diesel truck? Are there any lighter double mass flywheels (stock style) that are lighter which would eliminate the chatter (I can't find any)? Edited November 6, 2019 by chaseincats Link to comment Share on other sites More sharing options...
siteunseen Posted November 6, 2019 Share #31 Posted November 6, 2019 On 11/6/2019 at 2:40 PM, chaseincats said: How loud are these lightened flywheels? I've heard they make a noise similar to a diesel truck? Are there any lighter double mass flywheels (stock style) that are lighter which would eliminate the chatter (I can't find any)? Expand Never heard that before. Get your OE one cut and lightened. Thats the cheaper route. 1 Link to comment Share on other sites More sharing options...
chaseincats Posted November 6, 2019 Share #32 Posted November 6, 2019 On 11/6/2019 at 4:14 PM, siteunseen said: Never heard that before. Get your OE one cut and lightened. Thats the cheaper route. Expand This is an extreme example of the single mass (light) flywheel noise - https://www.youtube.com/watch?v=3vUdmshAsYM&t=20s I've heard shaving down the OE flywheel can weaken it to the point it may shatter if done improperly - is this true? 1 Link to comment Share on other sites More sharing options...
grannyknot Posted November 6, 2019 Share #33 Posted November 6, 2019 On 11/6/2019 at 4:31 PM, chaseincats said: I've heard shaving down the OE flywheel can weaken it to the point it may shatter if done improperly - is this true? Expand Sure, if done improperly or too much is taken off, it's the kind of job you want the oldest guy in the shop to do and know that he does it often. 2 Link to comment Share on other sites More sharing options...
LeonV Posted November 7, 2019 Share #34 Posted November 7, 2019 Stock flywheels are single mass, dual mass flywheels were not around when these cars were built. A light one won't be any more noisy than OEM. 1 Link to comment Share on other sites More sharing options...
chaseincats Posted November 7, 2019 Share #35 Posted November 7, 2019 On 11/7/2019 at 3:51 AM, LeonV said: Stock flywheels are single mass, dual mass flywheels were not around when these cars were built. A light one won't be any more noisy than OEM. Expand Ah ok, good to know. Is the transmission chatter then a thing that happens when putting a single mass flywheel on a car designed for a double? Link to comment Share on other sites More sharing options...
LeonV Posted November 8, 2019 Share #36 Posted November 8, 2019 On 11/7/2019 at 4:41 AM, chaseincats said: Ah ok, good to know. Is the transmission chatter then a thing that happens when putting a single mass flywheel on a car designed for a double? Expand That's been my experience, yeah. 1 Link to comment Share on other sites More sharing options...
