Camshaft oil sprayer
Spraying carb cleaner on there is also a good way to clean one.  I soaked mine in lacquer thinner for a few days then hit it with 120psi air gun. Theeeeeen OCD'd the spray holes with  4 penny finish nail.  You should also go with a high flow oil pump from a turbo ZX if you really want to soak the valve train.
That movie had a lot of good lines, esp from the late Bill Paxton.
oh back to the orig comment, run it without the valve cover to check function of the spray bar very long and you will think something was nuked from orbit from the mess it makes.
Edited by Dave WM
  • Who's Online   0 Members, 0 Anonymous, 997 Guests (See full list)
