Posted May 21, 200321 yr comment_38285 I just installed a set of prime 5 spoke wheels on my 280Z. They had never been mounted, because the original owner screwed up on his back space calculations. He had 15x7 wheels with 215/60-15 tires. They fit fine on the back, but not on the front (needed an additiional 7/8" offset. I dropped the size to 205/60-15s on the front and with a 1/2" spacer, it worked fine. However, The track appears significantly wider in the front, than the back (1/2" per side).Will this effect the handling and should I install the same spacers on the rear to equalize the track? It appears to drive fine, street speeds, etc.Any thoughts.ecp48 Link to comment https://www.classiczcars.com/forums/topic/6259-track-changeseffect-on-handling/ Share on other sites More sharing options...
