August 7, 20195 yr comment_581377 Canucks! On sale now: https://www.princessauto.com/en/detail/air-belt-sander/A-p8572208e Edited August 7, 20195 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-581377 Share on other sites More sharing options...
August 7, 20195 yr comment_581378 26 minutes ago, 240260280 said: Canucks! On same now: https://www.princessauto.com/en/detail/air-belt-sander/A-p8572208e A must for port and polish, I'm going to stop by on the way home tomorrow. Thanks Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-581378 Share on other sites More sharing options...
August 7, 20195 yr comment_581382 I’ve had one for a while. Work great but hard to get a good selection of the sanding belts. They don’t last long when you catch an edge. Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-581382 Share on other sites More sharing options...
August 7, 20195 yr Author comment_581390 Lots of useful info. Thanks very much. Now to the next question: What processes and/or chemicals do you recommend to prepare the welded area for primer and paint? Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-581390 Share on other sites More sharing options...
August 7, 20195 yr comment_581391 I like to paint phosphoric acid on metal then wipe with acetone when dry. Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-581391 Share on other sites More sharing options...
August 7, 20195 yr comment_581402 After grinding and sanding, I normally I use a wire brush, lacquer thinner, and Zinc rich primer. Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-581402 Share on other sites More sharing options...
August 7, 20195 yr comment_581416 I use the 3M Corps weld grinding wheel with a small die grinder. You can really knock off the high spots with precision then I use the angle grinder with the sandpaper to finish it off. Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-581416 Share on other sites More sharing options...
August 25, 20195 yr Author comment_582570 @SledZ Can you be a little more specific about the '3M weld grinding wheel' that you use? They have dozens of products that fall into the weld-grinding category. Do you have the 3M product number or name? Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-582570 Share on other sites More sharing options...
August 25, 20195 yr Author comment_582571 @240dkw That wire sounds intriguing. Unfortunately, it looks like the manufacturer only offers it in 11-lb spools (Cdn $130 plus tax & shipping from KTS Tools). That's good for commercial shops, I'm sure, but it represents a lot more welding than I need to do (or at least a lot more than I'm hoping I need to do ). Other members with more ambitious build programs may want to try it out, though, so thanks for the tip. Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-582571 Share on other sites More sharing options...
August 25, 20195 yr comment_582591 That is what I bought. I have some left over of course, would you like me to put some on a smaller spool and send it to you? Price sure has gone up, l think I paid around 80 cdn about 5 years ago. Edited August 25, 20195 yr by 240dkw Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-582591 Share on other sites More sharing options...
August 25, 20195 yr comment_582598 Yep its here on Amazon. I used only one wheel for dozens of long welds. It's a really good grinding wheel. https://www.amazon.com/3M-1991-Reinforced-Grinding-Wheels/dp/B0002SRLF2 Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-582598 Share on other sites More sharing options...
August 25, 20195 yr Author comment_582604 45 minutes ago, SledZ said: Yep its here on Amazon. I used only one wheel for dozens of long welds. It's a really good grinding wheel. https://www.amazon.com/3M-1991-Reinforced-Grinding-Wheels/dp/B0002SRLF2 Interesting. It's promoted by 3M as a cut-off wheel, although they say in the spec sheet that it's suitable for cutting and grinding. There are 4 sizes (diameters) offered, each with its own centre hole size. The 3" disc you're apparently using has a 3/8" centre hole. Does your die grinder have a 3/8" chuck, or do you use a step-down mandrel to adapt to a 1/4" chuck? Link to comment https://www.classiczcars.com/forums/topic/62590-grinding-weld-beads-recommendations-please/?&page=2#findComment-582604 Share on other sites More sharing options...
