Recently Browsing 0
I have spent the last few days trying to solve my engine problem with no luck so far. The motor has been running for a week with oil pressure that would get higher with engine RPM. I did a search and figured it was the pressure relief in the oil pump. I took the relief out of the oil pump and everything looked good. After reinstalling it, I had the same problem. I then installed a gauge in the oil sensor port and ran it for a while. It started to run at a nice 60 psi. And I thought I had fixed it but at the same time it started to run really rough. And of course really started smoking out the exhaust. I pulled the plugs and all six looked nasty. Black and oily. The fact that all of the plugs are dirty is odd. I pulled the PCV hose off and ran it for a while to see if any oil was coming from there and back to the intake but it was good.I then did a compression test with the following results.
#1 - 158
#2 - 159
#3 - 160
#4 - 160
#5 - 158
#6 - 157
I then did a leak down test
#1 - 100/92
#2 - 100/94
#3 - 100/92
#4 -100/94
#5 - 100/81
#6 - 100/80
I can hear the air leaking somewhere on both 5 and 6
So I pulled the head off.
There is a fair bit of oily, black soot inside the cylinders. Everything looks good on the head gasket, so I have not found anything yet. As it is in all 6 cylinders I do not understand where it is coming from.
Is it possible for the oil to be passing by the rings and still get that good of compression results?
What would the cylinders look like if it was a coolant leak instead of oil?
https://www.classiczcars.com/forums/topic/62626-engine-burning-oil/Share on other sites
