August 15, 20195 yr Author comment_582008 Hey guys update on my engine, so I found out that when my engine is rebuilt, instead of the 153624 order on the dizzy cap my mechanic did backed it up with 5 on 1and has a different timing I don't know how did he position the oil pump drive shaft tang during the rebuild. That's is why I can't ever make it run with the OE set up. Was just wondering what drive shaft tang position it was in before. The mistake I made when I pulled my oil pump. Should've pulled the dizzy first and marked the tang hold it with vice grip. Well atleast I learned something. Link to comment https://www.classiczcars.com/forums/topic/62655-75-280z-wont-run/?&page=2#findComment-582008 Share on other sites More sharing options...
August 16, 20195 yr comment_582011 So does it run now? Link to comment https://www.classiczcars.com/forums/topic/62655-75-280z-wont-run/?&page=2#findComment-582011 Share on other sites More sharing options...
August 16, 20195 yr comment_582015 1 hour ago, @honti10 said: Hey guys update on my engine, so I found out that when my engine is rebuilt, instead of the 153624 order on the dizzy cap my mechanic did backed it up with 5 on 1and has a different timing I don't know how did he position the oil pump drive shaft tang during the rebuild. That's is why I can't ever make it run with the OE set up. Was just wondering what drive shaft tang position it was in before. The mistake I made when I pulled my oil pump. Should've pulled the dizzy first and marked the tang hold it with vice grip. Well atleast I learned something. What?? And that makes sense to you why? Link to comment https://www.classiczcars.com/forums/topic/62655-75-280z-wont-run/?&page=2#findComment-582015 Share on other sites More sharing options...
August 16, 20195 yr comment_582016 Say whaaaaaaatttt? Link to comment https://www.classiczcars.com/forums/topic/62655-75-280z-wont-run/?&page=2#findComment-582016 Share on other sites More sharing options...
August 16, 20195 yr Author comment_582019 Yes, it is running now, settings based on FSM. No wonder I can't make it run. My mechanic has the entire spark plugs backed up, instead of regular 153624 he put it like this. Well its running perfect before! Dropped that pump, put it 11:25 won't run! Was just dumb enough not to notice in the beginning that it was set up that way! I just couldn't understand how the heck he put the oil shaft tang. Link to comment https://www.classiczcars.com/forums/topic/62655-75-280z-wont-run/?&page=2#findComment-582019 Share on other sites More sharing options...
August 16, 20195 yr Author comment_582020 Hey guys update on my engine, so I found out that when my engine is rebuilt, instead of the 153624 order on the dizzy cap my mechanic did backed it up with 5 on 1and has a different timing I don't know how did he position the oil pump drive shaft tang during the rebuild. That's is why I can't ever make it run with the OE set up. Was just wondering what drive shaft tang position it was in before. The mistake I made when I pulled my oil pump. Should've pulled the dizzy first and marked the tang hold it with vice grip. Well atleast I learned something. Link to comment https://www.classiczcars.com/forums/topic/62655-75-280z-wont-run/?&page=2#findComment-582020 Share on other sites More sharing options...
August 16, 20195 yr Author comment_582021 This case is closed! Link to comment https://www.classiczcars.com/forums/topic/62655-75-280z-wont-run/?&page=2#findComment-582021 Share on other sites More sharing options...
