Hey guys, I have 5 hours to burn and have found a cool salvage yard. It has three 280z’s and one 240z. If you need something that’s not really big or difficult to remove post in this thread and I’ll see what I can do for you. This is where I found Mikes ashtray for his 240z a few months ago.
https://www.classiczcars.com/forums/topic/62664-anybody-need-some-misc-parts/
I have a couple of things I would like to have. If it's not too much trouble.
280Z:
- The two fusable link holders on the passenger strut tower with about 12 inches of wire. It's the bottom section od POS#17 in the parts list drawing. Don't need the plastic covers or the links.
- Engine bay wiring harness staps that click into the panels.
- The 4x  M3 clips on the 280Z grill. It's where the vertical bar connects to the bottom horizontal bar.
I recently received a fusible link upgrade from a Cadillac car from @wal280z
I'm not doing the swap until it cools off here, October maybe? If I end up not using those you're welcome to them.  I haven't spent time reading the directions yet so I'm not positive it's still used?
  On 8/15/2019 at 4:49 PM, Patcon said:
You should get the early gas cap and ring if it's not too bad. Have it plated or send it to Jim (jfa) to have it plated
Got the 240z gas cap.
Anybody need one?
  On 8/15/2019 at 6:23 PM, gwri8 said:
If there is an early 77' with the sloped rear panels, I'm looking for the interior plastic rear finish panel, #47 in this picture.  I'm also looking for #'s 25 & 26 (side sloped panels).  Thanks!
Do you have the elastic cord and hook that holds the rear deck while messing with the spare? Those are mostly broken.
