Posted August 16, 20195 yr comment_582012 Need some Help... The issue I'm having is idle hanging up around 1500. It will lower to normal (900 rpm) if I blip throttle. Getting tired of doing that in traffic. Middle carb is hanging , but only when engine is running. Carbs open and fully shut very smooth when engine off. Vacuum holding plates open?. Maybe it has to do with the balance tube on the cannon manifold. all carbs have been rebuilt. I swapped carb position and problem stays in middle carb. I heard the cannon manifold suck. Does anyone have some helpful info for me? TIA. 20190815_164848.mp4 20190815_164500.mp4 20190815_180041.mp4 Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/ Share on other sites More sharing options...
August 16, 20195 yr comment_582018 If you pull the pedal up with your toe does that solve it? Fast idle means air is getting from somewhere. B;ipping the throttle just lets the blades slam shut instead of sticking on a slow close. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582018 Share on other sites More sharing options...
August 16, 20195 yr comment_582043 Same issue on my triples with Cannon intake; was getting stuck idle no matter what I did! After some reading, and discussion with Mike at Pierce Manifolds, I am a believer that the 3 post/rod ends are causing binding that will not be easily resolved. Essentially, it is very difficult to get all three "holes" to line up perfectly for the rod, thus causing a bind. I am going to try removing the center rod post (run on 2 rod ends, not 3), increase the rod and rod ends to 3/8" and see if the linkage will be much smoother. Otherwise, will move on to another intake manifold, if necessary. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582043 Share on other sites More sharing options...
August 16, 20195 yr Author comment_582046 @Zed Head I have a cable set up, so pulling up on pedal does nothing for me . I'll check again for air leaks. Thank you for your time Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582046 Share on other sites More sharing options...
August 16, 20195 yr Author comment_582047 Hey @duffman I tried removing the center post last year and it did not help at all. Good luck. I just order a external spring linkage though pierce manifold (Search DCOE external spring on google) hopefully that solves it. If not I'm buying a new manifold. I 'll let you know. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582047 Share on other sites More sharing options...
August 16, 20195 yr comment_582048 On 8/16/2019 at 4:29 PM, Rio24 said: @Zed Head I have a cable set up, so pulling up on pedal does nothing for me . I'll check again for air leaks. Thank you for your time My cable setup will still close the butterfly when I pull up on the pedal... Edit: NVM, I missed the cable to bar linkage issue. Edited August 16, 20195 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582048 Share on other sites More sharing options...
August 16, 20195 yr comment_582049 Rio24, I have been told that the 5/16" rod that comes with the intake is not as good as the 3/8" stainless steel rod that Pierce Manifold sells. You may have removed the center post, but still used the smaller (thinner) rod and that doesn't work as well, am told. I am also getting sticking even with the cable linkage. Edited August 16, 20195 yr by duffman Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582049 Share on other sites More sharing options...
August 16, 20195 yr comment_582050 On 8/16/2019 at 4:29 PM, Rio24 said: @Zed Head I have a cable set up, so pulling up on pedal does nothing for me . I'll check again for air leaks. Thank you for your time That tells you that the binding is at the throttle linage on the manifold, not at the cable or the pedal. You can extend the the thought process and push on the linkage with your finger. Open the hood and poke around and you'll probably realize something. Your picture shows that you have quite a bit of slack in your cable. Seems like a good tune of the overall system might help. Lots of adjustable bits there. Edited August 16, 20195 yr by Zed Head pole poke Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582050 Share on other sites More sharing options...
August 17, 20195 yr Author comment_582067 @duffman you have a good point! Now should I try the beefer rod for 150 and hope that takes care of the issue or spend 500 on kenmeri manifold?!! Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582067 Share on other sites More sharing options...
August 17, 20195 yr comment_582068 The total from Pierce Manifold for the 16" x 3/8" rod, 2 - 3/8" rod ends, adapters for the Cannon intake and 2 - 3/8" end links to hold the rod in place amount to about $80. Pretty cheap alternative to a new intake (at least to start!) Edited August 17, 20195 yr by duffman Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582068 Share on other sites More sharing options...
August 17, 20195 yr comment_582069 No offense intended to the guys with the problem but buying a new manifold to fix a linkage problem makes little sense. There are three throttle blades and linkage to make them work together. If the blades aren't sticking it's the linkage. If a new manifold works it's because it came with new linkage. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582069 Share on other sites More sharing options...
August 17, 20195 yr comment_582070 That is why $80 to fix the linkage is a better option to begin with, Zed Head, I agree it doesn't make sense to throw big money at it, if you don't have to! Edited August 17, 20195 yr by duffman Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/#findComment-582070 Share on other sites More sharing options...
