August 17, 20195 yr Author comment_582115 Thats great info @Zed Head these carbs dont have vacuum ports. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582115 Share on other sites More sharing options...
August 17, 20195 yr comment_582116 Look for a leak at the blade area. You're looking for something causes a pressure imbalance at the blade edge. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582116 Share on other sites More sharing options...
August 17, 20195 yr Author comment_582118 Im on it! Thanks. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582118 Share on other sites More sharing options...
August 18, 20195 yr comment_582121 Quote: " I swapped carb position and problem stays in middle carb. " I must be missing something. If a good carb does the same thing in the center position, then it can't be the carb or the linkage Also, If the linkage is disconnected as shown then the linkage is out of the equation completely. So its been good all the while you had it and then turned to crap after carb rebuild? Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582121 Share on other sites More sharing options...
August 18, 20195 yr comment_582122 In the last video he mentioned that the other carb did it too. It's near the end... Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582122 Share on other sites More sharing options...
August 18, 20195 yr Author comment_582123 I rebuilt carbs trying to fix tbis problem @gundee. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582123 Share on other sites More sharing options...
August 18, 20195 yr comment_582130 Clearly the internal return spring on that middle carb isn't doing its job. Either the spring is weak or the throttle shaft or plates are binding. If you disconnect the internal spring, you'll be able to feel whether there's any binding.Even without fixing the problems on the individual carbs, the linkage with a strong spring should be able to pull all throttles closed. If it can't, and it's not a throttle stop on the linkage limiting it, then I would think the carbs aren't balanced perfectly and one of the other carbs has reached its stop earlier and is preventing further movement of the linkage. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582130 Share on other sites More sharing options...
August 18, 20195 yr comment_582166 23 hours ago, Zed Head said: In the last video he mentioned that the other carb did it too. It's near the end... Then one carb is all good and 2 are sticking? Just to clarify. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582166 Share on other sites More sharing options...
August 19, 20195 yr Author comment_582170 @gundeeIt's just the middle carb sticking. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582170 Share on other sites More sharing options...
August 19, 20195 yr comment_582171 Somebody's voice says "that one sticks a little bit too" at second 12 in the video. The video's only 25 seconds long... There's a lot of randomness in this thread. Carbs are pretty simple. Your finger acted as a "spring" in the video itself. You just need more force to close the blades. Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582171 Share on other sites More sharing options...
August 19, 20195 yr Author comment_582172 That was a co workers voice and it was fake news. Just middle one sticks and its not the carb because I switch carbs around and sticks to middle position. There are many triple weber config running with 0 or just 1 weak return spring. I wish it was just that. Please understand that it is beyond adding more return springs. I'm determined to get this solved. Thanks for the help. I will definitely post the solution on this thread Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582172 Share on other sites More sharing options...
August 19, 20195 yr comment_582174 No offense. But there's no target to shoot at... Your posts are full of distracting information, then you say "I already checked that" when people make suggestions. "Please understand"? You came here asking... Seems like you're trying to make sure that only you find the solution. Good luck. Edited August 19, 20195 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/62668-sticky-idle/?&page=3#findComment-582174 Share on other sites More sharing options...
