Posted May 22, 200321 yr comment_38320 Generally speaking what would you expect to get if you were to buy a head from an individual? Link to comment https://www.classiczcars.com/forums/topic/6267-how-much-would-you-expect/ Share on other sites More sharing options...
May 22, 200321 yr comment_38323 Originally posted by texasz Generally speaking what would you expect to get if you were to buy a head from an individual? I'm not sure I understand your question, but if you mean how complete would I expect the head to be (what would I expect to GET if I were to BUY a head); I'd expect to get everything (except the oil tube, as I always buy a new one). Head itself, cam towers, cam, springs, and valves. Link to comment https://www.classiczcars.com/forums/topic/6267-how-much-would-you-expect/#findComment-38323 Share on other sites More sharing options...
May 22, 200321 yr Author comment_38414 Yes bambi, that is what I was asking. That is what I expected too but the seller pulled the cam and valve cover off. I must say that I am partially at fault for not being 100% clear on what I expected. He is making good on it though, late last night he said that I can have the missing items. I just wanted to make sure that I was not being unreasonable in expecting thecomplete head ready to bolt onto a block. Link to comment https://www.classiczcars.com/forums/topic/6267-how-much-would-you-expect/#findComment-38414 Share on other sites More sharing options...
May 22, 200321 yr comment_38428 Originally posted by texasz Yes bambi, that is what I was asking. That is what I expected too but the seller pulled the cam and valve cover off. I would expect it to be ready to bolt on, but would not expect the head bolts or valve cover to be part of the deal. cam should definitely be included, unless specified otherwise. Link to comment https://www.classiczcars.com/forums/topic/6267-how-much-would-you-expect/#findComment-38428 Share on other sites More sharing options...
