November 3, 20195 yr comment_586872 1 hour ago, Yarb said: During this procedure will the fuel normally bypass the regulator and go to my return tank? On Initial turnover I’m getting 36psi and after it sits for a few minutes it drops down to 10lbs static. Meanwhile I’ve sent a lot of fuel to the return tank. Yes, that's how the system works. Fuel passes through the regulator back to the tank after 36 psi is reached. The fact that it leaks down after the engine dies might affect starting time but won't affect how it runs once it starts. You have a running problem not a starting problem. Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586872 Share on other sites More sharing options...
November 4, 20195 yr comment_586877 So the needle nose technique causes restraint in the system. Does that point to the regulator if it runs? Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586877 Share on other sites More sharing options...
November 4, 20195 yr comment_586879 It will restrict the flow back to the tank therefore stopping the 36psi to 10psi. Just another trouble shooting technique I've used. Do you have the OEM FPR still? They rarely go bad but they do occasionally. The aftermarket ones are $^!#. Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586879 Share on other sites More sharing options...
November 4, 20195 yr comment_586880 The factory oe is on it now. Have a Bosch 64018 replacement coming tomorrow Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586880 Share on other sites More sharing options...
November 4, 20195 yr comment_586881 He's reaching 36 psi. The pump and regulator seem to be fine. Leakdown happens when the pump is not running, it's a starting problem. I think that we might be getting our diagnostic methods mixed together here.  Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586881 Share on other sites More sharing options...
November 4, 20195 yr comment_586882 The new FPR will probably not fix your running problem. The engine will just start and die more quickly. Just trying to be clear.... Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586882 Share on other sites More sharing options...
November 4, 20195 yr comment_586899 Not sure where to go from here. It turns over, I have spark, acts like it’s begging for fuel. Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586899 Share on other sites More sharing options...
November 4, 20195 yr comment_586902 4 hours ago, Zed Head said: Just pop off the plug at the round sensor/switch on the side of the engine block.. Turn the key on and the pump should start running. It's a good test of the fuel pump control system. When you're working with these EFI systems you really need to make a list of things to check and follow it, unless you have a really good memory. Make a list then run through it, check, check, check.... Otherwise things will look like just a bunch of random actions and results. Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586902 Share on other sites More sharing options...
November 4, 20195 yr comment_586909 More than likely from sitting dormant for 12 years, the fuel has gummed up / seized many or all of the injectors causing them to not spray fuel with the pulse.  Try to listen to them while a assistant is cranking the motor. They make a distinctive click sound, a stick or long screwdriver held to your ear works well. Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586909 Share on other sites More sharing options...
November 4, 20195 yr comment_586910 Thanks Zed, I’ll let you know what I find Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586910 Share on other sites More sharing options...
November 4, 20195 yr comment_586911 Injectors were sent to HPI and rebuilt. New OEM pump. While apart I checked the AFM, TPS, Thermotime switch for CSV and the thermostat to ECU. Went step by step by the FSM. Only part could not check static was the fuel pressure regulator. Definitely had corrosion issues on most connectors which I resolved. All vacuum and fuel lines replaced. Thanks for your input much appreciated Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586911 Share on other sites More sharing options...
November 4, 20195 yr comment_586925 8 hours ago, Yarb said: Injectors were sent to HPI and rebuilt. New OEM pump. While apart I checked the AFM, TPS, Thermotime switch for CSV and the thermostat to ECU. Went step by step by the FSM. Only part could not check static was the fuel pressure regulator. Definitely had corrosion issues on most connectors which I resolved. All vacuum and fuel lines replaced. Thanks for your input much appreciated above is a test you can do. Link to comment https://www.classiczcars.com/forums/topic/62670-fuel-rail-and-pressure-regulator-suggestions-78-280z/?&page=3#findComment-586925 Share on other sites More sharing options...
