Posted August 23, 20195 yr comment_582438 Does anyone have the dimensions on the rear wheel bearing spacer, marked "B"? Only dimension (including tolerance) I can find in the FSM is the length. Need to know the I.D and O.D as I need to make a set. Link to comment https://www.classiczcars.com/forums/topic/62711-dimensions-rear-wheel-bearing-spacer-b/ Share on other sites More sharing options...
August 23, 20195 yr comment_582445 I don't have the dimensions written down, but I will get them. I can tell you, however, that (within wide limits), those two dimensions aren't really important. It has to be big enough on the ID to pass over the bearing surfaces without binding, and it has to be small enough on the OD so it doesn't interfere with grease flow into the balls. Other than that, it doesn't really matter. Link to comment https://www.classiczcars.com/forums/topic/62711-dimensions-rear-wheel-bearing-spacer-b/#findComment-582445 Share on other sites More sharing options...
August 27, 20195 yr Author comment_582706 Yes, I know its not super critical but better to have the exact dimensions if possible. Would appreciate it if you could give them to me? Link to comment https://www.classiczcars.com/forums/topic/62711-dimensions-rear-wheel-bearing-spacer-b/#findComment-582706 Share on other sites More sharing options...
August 28, 20195 yr comment_582718 Sorry for the delay. ID of the spacer tube is 1.290 inches. My assumption is that the original target was 32.75 mm OD of the spacer tube is 1.685 inches. My assumption that the original target was 42.75 mm Anything close to that would be fine. The OD of the stub axle where the bearings reside is 1.250 inches. This means that the 1.290 ID of the spacer tube results in about .020 inch (0.5mm) gap per side if you get the spacer centered. So reverse engineering the design, I'm theorizing they picked the size something like this... "ID of the spacer to be 1 mm larger than the OD of the shaft, and it should have a 5.0 mm wall thickness." Link to comment https://www.classiczcars.com/forums/topic/62711-dimensions-rear-wheel-bearing-spacer-b/#findComment-582718 Share on other sites More sharing options...
August 28, 20195 yr comment_582767 Hate to say it, but I send you a couple of B spacers if you want.... Link to comment https://www.classiczcars.com/forums/topic/62711-dimensions-rear-wheel-bearing-spacer-b/#findComment-582767 Share on other sites More sharing options...
August 30, 20195 yr Author comment_582947 On 8/28/2019 at 9:06 PM, zKars said: Hate to say it, but I send you a couple of B spacers if you want.... Really appreciate the offer but I don't need a set anymore. Bought a set of stubs and the guy that sold them to me was nice enough to include the spacers? Link to comment https://www.classiczcars.com/forums/topic/62711-dimensions-rear-wheel-bearing-spacer-b/#findComment-582947 Share on other sites More sharing options...
