Posted August 28, 20195 yr comment_582791 I just never seem to learn. Needed some 1/4 to 1/2" spacers for the last couple of sets of front wheels I've had on my 510 to get them to clear the coil overs and fit the car right. Everybody does this to trim-out-the-fitment thing. Well I went to the speed shop and bought some that are 3/8". How hard is it to get a flat piece of metal with some holes in it? Well I learned the hard way, again. Very hard apparently. The only ones they had were, shall we say, not very expensive. These cast aluminum or unknown pot metal something's are absolutely pieces of you-know-what. I have been battling wheel shimmy for months, and never dreamed it would be these things. They are only 0.015 inch variance in thickness, but that amount, magnified out to the wheel/tire diameter made the wheels run out by 0.050 inches, which is nearly 1/16". Replaced them with these. Had a local metal shop laser cut these in 15 min. 5.75 diameter, 3" center hole, 1/2 diameter bolt holes at 4.5 bolt spacing. 1/4" 6061 TOTALLY REMOVED ANY AND ALL STEERING WHEEL VIBRATION I HAD, and it was not insignificant. Almost made it unpleasant to drive. Reminded me of this Beware! I wonder where they are made.... hmmmmmm.... Another way to see just how anti-flat these are. I sprayed them lightly with black and gave them a quick surface sanding on my reference flat abrasive platten (3/4" MDF with glued on sand paper). Edited August 28, 20195 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/62743-bad-spacer-bad/ Share on other sites More sharing options...
August 29, 20195 yr comment_582801 https://globalnews.ca/news/3559236/humboldt-rcmp-fake-canadian-currency-blue-chinese-characters/ Link to comment https://www.classiczcars.com/forums/topic/62743-bad-spacer-bad/#findComment-582801 Share on other sites More sharing options...
August 29, 20195 yr comment_582829 Frankly I'm a little disappointed. The zKars I know would have spent an unreasonable number of hours filing and measuring the POS pot metal spacer until it was accurate. Link to comment https://www.classiczcars.com/forums/topic/62743-bad-spacer-bad/#findComment-582829 Share on other sites More sharing options...
August 29, 20195 yr comment_582831 Give the man a lathe! Link to comment https://www.classiczcars.com/forums/topic/62743-bad-spacer-bad/#findComment-582831 Share on other sites More sharing options...
August 29, 20195 yr Author comment_582833 Man has lathe, mill and drill press and most definitely 'could' have made my own, did considered filing, but was not at home at the time of the discovery and need for a solution. Had to resort to the solution of spending money. But thanks for the vote of confidence. Link to comment https://www.classiczcars.com/forums/topic/62743-bad-spacer-bad/#findComment-582833 Share on other sites More sharing options...
August 29, 20195 yr comment_582835 14 hours ago, 240260280 said: https://globalnews.ca/news/3559236/humboldt-rcmp-fake-canadian-currency-blue-chinese-characters/ Should the Chinese characters be in a different color for legitimate Canadian currency? Link to comment https://www.classiczcars.com/forums/topic/62743-bad-spacer-bad/#findComment-582835 Share on other sites More sharing options...
August 29, 20195 yr comment_582874 6 hours ago, zKars said: thanks for the vote of confidence. LOL. Absolutely. Never a doubt. Link to comment https://www.classiczcars.com/forums/topic/62743-bad-spacer-bad/#findComment-582874 Share on other sites More sharing options...
