The bezel is part of the switch now.
This is what I got and removed the rubber grommet for the right switch but it looks like the left one with the 4 wires is NLA. That said, you could just get one for each side and ignore the buzzer wire.
34 minutes ago, 77Z said:
If you're saying I could buy the switch and get the bezel I'd by two of the right side switches just to get the rubber grommets.... and chunk the switch.
the bezel is molded into the metal of the switch housing
Edited by chaseincats
If this is a picture of what you're talking about, I don't think it'll work. That wouldn't cover the two holes in the '77Z door well which the grommet goes into. The grommet I need is as in the photo, roughly 3 in tall 1 in wide, rubber.
I'll take a pic of mine when I get home tonight - hold
EDIT: I checked and apparently I re-used the rubber grommet I had on there when I swapped out the switches
I searched everywhere with no luck at all when I was getting the car painted a few months ago. Hopefully someone will reproduce them. 240Z rubber didn’t seem interested in taking it on at the time I inquired.
