September 6, 20195 yr comment_583412 Another thought, and a reason to just go through the whole series of EFI component tests and measurements. If your coolant temperature sensor circuit is "open" the ECU will dump loads of extra fuel thinking that it's super cold out. It might be that that is the reason the PO lowered the fuel pressure. You already have many of the important numbers. Keep measuring and confirming. A multimeter is a very valuable tool for the EFI systems. You might save yourself some time and money by doing the full set of tests first. Edited September 6, 20195 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583412 Share on other sites More sharing options...
September 7, 20195 yr Author comment_583460 Going to leave the AFM alone for now. Planning on going through the fuel injection system and testing everything we can, testing vacuum, etc. Did fine out a few more pieces of info. Haven't verified, but PO says the injectors should be original type, not turbo (we'll see). He did change out the throttle body, as many had observed. He also switched the cam to a Schnieder Racing Cam. I'm not sure exactly what that does or will mean, but one more piece of the puzzle. My son turned 16 two days ago, so he wanted to get up early and go to Cars and Coffee. Gratuitous pic of him (the one with long hair) next to his car. He had a blast and we had a lot of people stopping to talk. Everyone had one or knew someone who did and have fond memories. Was fun. Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583460 Share on other sites More sharing options...
September 7, 20195 yr comment_583462 The factory system probably won't like the schneider cam. Schneider offers a lot of different cams. You will need to try to pin that down further Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583462 Share on other sites More sharing options...
September 7, 20195 yr Author comment_583463 Will figure out how to get the exact model/type cam. And thanks to everyone for setting me straight on the AFM. When it didn't look like the pics and with all the stuff from JEGS PO had ordered, my mind just saw that vs JECS... Need to pay more attention... Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583463 Share on other sites More sharing options...
September 8, 20195 yr Author comment_583496 Question for everyone. How do I identify the model/type of cam? Pulled the valve cover, but the camshaft is just labeled Japan and C on one side, and E30 on the other. The C is on it's own raised section on the shaft. To fully identify, would I need to pull the camshaft? If so, I have a bit of research to do as I've never done so. Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583496 Share on other sites More sharing options...
September 8, 20195 yr comment_583498 Here's a Schneider I have. The front is scribed with the info. Go to Schneider's website and find the info. Mine is a 280F You'll have remove the cam sprocket though I beleive. Whole nother can of worms! Edited September 8, 20195 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583498 Share on other sites More sharing options...
September 8, 20195 yr comment_583503 Older Efi cars use milder cams from what I've read. Go to motorsportsauto.com or MSA and read their cam recommendations for fuel injection. They sale Schneider cams. You might save yourself some trouble just assuming your cam came from them? A shot in the dark... Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583503 Share on other sites More sharing options...
September 8, 20195 yr comment_583513 I just noticed something odd, but can't be sure. It looks like the pressure gauge might be on the return line to the tank. It should be between the fuel filter and the rail. Not really sure how the pressure would vary with the vacuum hose connected if it is on the return line, but worth double checking. Maybe the FPR is connected incorrectly. Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583513 Share on other sites More sharing options...
September 8, 20195 yr comment_583514 Be very careful removing the cam sprocket. If you let slack into the chain the tensioner will pop out and it will require a lot more disassembly! Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583514 Share on other sites More sharing options...
September 8, 20195 yr comment_583516 On 9/8/2019 at 8:47 PM, Patcon said: Be very careful removing the cam sprocket. If you let slack into the chain the tensioner will pop out and it will require a lot more disassembly! There it is! If you're not careful that timing chain tensioner will ruin your day/week. The cheap plastic ones are very scary to use trust me. If you have some hardwood scraps you can make your own. I will trace around mine and fax it to you then you can make your own. If you get that far let me know. Yep, still have a fax machine. If YOU don't I will scan and email it to you. Edited September 8, 20195 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583516 Share on other sites More sharing options...
September 8, 20195 yr comment_583517 Oh, I'm talking about the tool you'll have to have to push in the tensioner. ? Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583517 Share on other sites More sharing options...
September 8, 20195 yr comment_583518 On 9/8/2019 at 8:43 PM, Zed Head said: I just noticed something odd, but can't be sure. It looks like the pressure gauge might be on the return line to the tank. It should be between the fuel filter and the rail. Not really sure how the pressure would vary with the vacuum hose connected if it is on the return line, but worth double checking. Maybe the FPR is connected incorrectly. Hard to tell isn't it! Link to comment https://www.classiczcars.com/forums/topic/62758-failed-co-emissions-all-controls-removed-where-to-start/?&page=7#findComment-583518 Share on other sites More sharing options...
