Posted August 31, 20195 yr comment_583010 Hi, I'm trying my hand at restoring a steering wheel and can't determine the function of this metal ring. It is a little rusty but I can't seem to remove it (that woild be nice) but if it doesnt matter I will leave it as is. --Thomas Edited August 31, 20195 yr by Tomcat Add pictures. Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/ Share on other sites More sharing options...
August 31, 20195 yr comment_583014 Soak the whole assembly in EvapoRust. Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-583014 Share on other sites More sharing options...
August 31, 20195 yr Author comment_583020 Thanks Mark. Will do. What is its function? Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-583020 Share on other sites More sharing options...
August 31, 20195 yr comment_583027 It holds the padded horn "button" in place. Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-583027 Share on other sites More sharing options...
September 1, 20195 yr comment_583052 it's actually a spring. Like CG said it fits into a groove in the horn pad to keep it on the wheel. Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-583052 Share on other sites More sharing options...
November 19, 20195 yr Author comment_587886 Completely disolved the ring. I see the kits around $60 on-line. If you have a used one for less please let me know. Edited November 19, 20195 yr by Tomcat Found replacement on-line but expensive. Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-587886 Share on other sites More sharing options...
November 19, 20195 yr comment_587908 On 11/19/2019 at 12:31 AM, Tomcat said: Completely disolved the ring. I see the kits around $60 on-line. If you have a used one for less please let me know. How did you dissolve the ring? Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-587908 Share on other sites More sharing options...
November 19, 20195 yr comment_587910 Did you use EvapoRust or some kind of acid? In any case you need a new one, I'll have a look through my stuff, I might have one. Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-587910 Share on other sites More sharing options...
December 14, 20195 yr Author comment_589228 Sorry for the slow reply. Yes, "Krud Kutter". Either it was mostly rust or I let it set too long. grannyknot, let me know if you have one. Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-589228 Share on other sites More sharing options...
December 15, 20195 yr comment_589255 Just had a look, I don't have a spare but we know someone who probably does, @zKars Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-589255 Share on other sites More sharing options...
December 15, 20195 yr comment_589256 I’ll look... Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-589256 Share on other sites More sharing options...
December 17, 20195 yr comment_589450 I looked. PM me so Santa can do his thing Edited December 17, 20195 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/62764-steering-wheel-parts/#findComment-589450 Share on other sites More sharing options...
