Under hood light
AZDatsun
This may be a stretch but my underhood light has never had the toggle switch it’s broken off at the base so I can’t turn the light on/off. The nut is still there though. Anyone ever replace just the switch? If so what did you use. Showing a picture of the part I am talking about.
I have a stash of the broken white plastic switches for these engine ights.  I picked up a metal one at Frye's similar to the one you have shown and used that instead.  I did take a little white paint and painted the lever part white just so it looks a bit like the original.
Hey Motorman,
Does the Fry's in SD look like it's going out of business?  I went to Fry's in Fountain Valley a couple of days ago
and the store is really empty. I guess Amazon and the other on line stores have really put the hurt on Fry's
44 minutes ago, ryanotown22 said:
Next I need to find a plastic light lens cover
Currently out of stock, but you can make contact to see when the lens will be available again if you haven't already checked.
https://www.240zrubberparts.com/apps/webstore/products/show/4519997
Dennis
