800RPM idle, good accel, timing off by 20 degrees!
DannDZ
I am attempting to tune my '71 with the old round top SUs. I performed a rudimentary (at best) carb tuning and then turned to the ignition. While tuning the engine I was able to get the it to idle well at 800 RPM and it had strong acceleration up to about 6K RPM and 90 MPH. (On a track only, of course! ?) But when I look at the ignition timing with a timing light, it shows that it is about 25-degrees BTDC!
The distributor is at its limit of adjustment. Is it possible/recommended that I remove the distributor itself and move it by "one position" to fix the problem and get me back to the right range where I can make timing adjustments just loosening the distributor cap and adjusting?
What is going on and how I can fix it?
Thanks!
If that's in 4th gear I'd leave it be. Pretty good numbers imo. But you could set it at tdc and remove the distributor and see where the spindle is. Should look like this...
 My distributor is maxed out too. I'm at 17 btdc and 34 full advance at 3,000 or 3,500? can't remember but at the higher rpm my timing mark is at 0. At idle its 17.
I'm no ignition guy but could you plugs wires be off on the cap?
Edited by siteunseen
is that at idle?  Do you have a vacuum hose connected to the vacuum advance?
Make sure that the rotor is actually pointed at #1 wire when the timing mark is close to zero.  Take the cap off to see.  Many possible causes for what you're seeing.
So many great suggestions! Thanks to everyone. I have much to learn. Today I am going to (try to) tune and balance my carbs. Then it is back to setting the ignition timing. Having not actively worked on it for about 20 years, I'd forgotten how interrelated everything is. An how ANALOG! Cars today make all those interdependent adjustments on their own.
Thanks again!
12 hours ago, 240260280 said:
Z's love advance while idling so 25 is fine....but it usually pings when under load as the rpms rise.
Starting would be  hard at 25!
I don't here any pings on load, but I can listen more carefully. When warm, haven't tried it cold yet, it starts with no choke and no foot on the accelerator. If I didn't know the timing was off, I'd think everything is fine.
11 hours ago, 240260280 said:
10 while cranking , 25 at idle, 32-38 max, and higher only  under cruise would be great
How can you tell the timing under all these different conditions? While cranking and idling I can understand, but how can it be measured at cruise? And, can you provide any insight on why everyone suggests that is may be OK when it is so far from what the manual says? Is it just the nature of a warn system that you adjust until it runs right, the book be damned?
Edited by DannDZ
Added question about why not the book values?
  • Who's Online   2 Members, 0 Anonymous, 1,015 Guests (See full list)
