If master has dried up or run empty while bleeding at wheel it needs to be bled.
Just buy new 4 pot toyota truck calipers. http://atlanticz.ca/zclub/techtips/toyotabrakeupgrade/index.html
https://www.rockauto.com/en/moreinfo.php?pk=311378&cc=1277153&jsn=726
https://www.rockauto.com/en/moreinfo.php?pk=311377&cc=1277153&jsn=712
Edited by 240260280
On 9/10/2019 at 12:30 PM, moozieman said:
I tried those. Maybe ill let it soak in some wd40 or sumn first
try a stud remover after soaking it in lube. I had to use it on many rusted bolts. note if the bolt breaks, you'll likely have to use a tap and die to rethred it.
https://www.amazon.com/ARES-70016-Damaged-Extractor-Removes/dp/B01GKEBG9I/ref=sr_1_3?keywords=stud+remover&qid=1569280591&s=gateway&sr=8-3
