February 28, 20205 yr comment_593363 I didn't think about that option. I'll have to go out to the garage and take a closer look at that option. Let you know. Thanks. Link to comment https://www.classiczcars.com/forums/topic/62834-remove-door-card-chrome-strip/?&page=2#findComment-593363 Share on other sites More sharing options...
February 28, 20205 yr Author comment_593364 okay, so you asked if anyone tried to remove the strip from the card. I tried heat, but chickened out quickly because I was concerned about melting the 45+ year old vinyl. My door cards and vinyl were in very good shape, with the exception of the strip. I really did not want to take a chance on ruining the vinyl. I was going to change the color of my vinyl and decided to go with the SEM spray for the vinyl and the Spaz Stix for the strip. The picture below shows what I was able to achieve. If you are retaining the current color of your vinyl then the problem is a bit easier as you only have to tape the vinyl tight to the strip. One word of advice the chrome spray is pretty good but not great. Your results are improved if the surface is really smooth, so dont sand, there is no paper that is really fine enough, but you do need to remove anything that is loose on the surface of the strip. I am not trying to discourage you from trying to remove the strip. I am concerned about getting the area hot enough to separate the strip from the vinyl without melting the vinyl. Best of luck. Link to comment https://www.classiczcars.com/forums/topic/62834-remove-door-card-chrome-strip/?&page=2#findComment-593364 Share on other sites More sharing options...
February 28, 20205 yr comment_593366 On 2/28/2020 at 8:32 PM, qz16 said: okay, so you asked if anyone tried to remove the strip from the card. I tried heat, but chickened out quickly because I was concerned about melting the 45+ year old vinyl. My door cards and vinyl were in very good shape, with the exception of the strip. I really did not want to take a chance on ruining the vinyl. I was going to change the color of my vinyl and decided to go with the SEM spray for the vinyl and the Spaz Stix for the strip. The picture below shows what I was able to achieve. If you are retaining the current color of your vinyl then the problem is a bit easier as you only have to tape the vinyl tight to the strip. One word of advice the chrome spray is pretty good but not great. Your results are improved if the surface is really smooth, so dont sand, there is no paper that is really fine enough, but you do need to remove anything that is loose on the surface of the strip. I am not trying to discourage you from trying to remove the strip. I am concerned about getting the area hot enough to separate the strip from the vinyl without melting the vinyl. Best of luck. Thanks for the heads up. I am planning to proceed very cautiously. The interior is perfect except for the strips. I've had the car since new and it was only not garaged for 2 months when first purchased. It has been garaged since then. Link to comment https://www.classiczcars.com/forums/topic/62834-remove-door-card-chrome-strip/?&page=2#findComment-593366 Share on other sites More sharing options...
February 28, 20205 yr comment_593367 We're gonna need to see some pictures of that beauty. It sounds nice and well taken care of. Cliff Link to comment https://www.classiczcars.com/forums/topic/62834-remove-door-card-chrome-strip/?&page=2#findComment-593367 Share on other sites More sharing options...
February 28, 20205 yr comment_593371 Here's some photos. Link to comment https://www.classiczcars.com/forums/topic/62834-remove-door-card-chrome-strip/?&page=2#findComment-593371 Share on other sites More sharing options...
