Posted September 15, 20195 yr comment_584023 Anybody here might have a good set laying around willing to sell? By that I mean with no " play " in the pivot points of the hinges.. Since my car was hit in the front a few years ago, and after the damage repair by the body shop, the hood was still to high up in the front, and the shop couldn't repair it they said.. I went looking for the problem last week, and found when I push the hood down with my hand, there is alot of play in the hinge, so I guess that when my car was hit, the bonnet was pushed up a little and this stretched the hinges out... ( before the hit the hood was aligning fine.. Bart Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/ Share on other sites More sharing options...
September 15, 20195 yr comment_584035 @zKars Edited September 16, 20195 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584035 Share on other sites More sharing options...
September 15, 20195 yr comment_584046 3 hours ago, bartsscooterservice said: Anybody here might have a good set laying around willing to sell? By that I mean with no " play " in the pivot points of the hinges.. Since my car was hit in the front a few years ago, and after the damage repair by the body shop, the hood was still to high up in the front, and the shop couldn't repair it they said.. I went looking for the problem last week, and found when I push the hood down with my hand, there is alot of play in the hinge, so I guess that when my car was hit, the bonnet was pushed up a little and this stretched the hinges out... ( before the hit the hood was aligning fine.. Bart Have you tried to adjust it? I have found many hinges will do this. Even a good pair. Many times you can loosen the bolts slightly and push down on the hood, then retighten them Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584046 Share on other sites More sharing options...
September 15, 20195 yr comment_584059 4 hours ago, Patcon said: Have you tried to adjust it? I have found many hinges will do this. Even a good pair. Many times you can loosen the bolts slightly and push down on the hood, then retighten them It can be done by yourself but much easier with a second person, you do one side at a time, loosen all four bolts holding the hinge to the body, have someone push down on the closed hood in the front corner and tighten the three bolts that you can get to and get the fourth later, then the other side the same. Also, you need to remove the grill. Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584059 Share on other sites More sharing options...
September 16, 20195 yr comment_584082 11 hours ago, bartsscooterservice said: Anybody here might have a good set laying around willing to sell? By that I mean with no " play " in the pivot points of the hinges.. Since my car was hit in the front a few years ago, and after the damage repair by the body shop, the hood was still to high up in the front, and the shop couldn't repair it they said.. I went looking for the problem last week, and found when I push the hood down with my hand, there is alot of play in the hinge, so I guess that when my car was hit, the bonnet was pushed up a little and this stretched the hinges out... ( before the hit the hood was aligning fine.. Bart If the adjustment suggestions don't work for you, I have a good pair of hinges that I'll be happy to sell. Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584082 Share on other sites More sharing options...
September 16, 20195 yr Author comment_584097 14 hours ago, Patcon said: Have you tried to adjust it? I have found many hinges will do this. Even a good pair. Many times you can loosen the bolts slightly and push down on the hood, then retighten them I tried that, it got a little better but still not good. Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584097 Share on other sites More sharing options...
September 16, 20195 yr Author comment_584098 6 hours ago, Namerow said: If the adjustment suggestions don't work for you, I have a good pair of hinges that I'll be happy to sell. € USD ? Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584098 Share on other sites More sharing options...
September 16, 20195 yr comment_584100 I found it worked a little easier after I removed the torsion bars. Loosen everything. Remove the torsion bars. Then close it. That will take all resistence out. Then reach in there and tighten everything down. Then reconnect the torsion bars. Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584100 Share on other sites More sharing options...
September 19, 20195 yr Author comment_584333 On 9/16/2019 at 10:57 AM, 87mj said: I found it worked a little easier after I removed the torsion bars. Loosen everything. Remove the torsion bars. Then close it. That will take all resistence out. Then reach in there and tighten everything down. Then reconnect the torsion bars. Tried that also, but I clearly SAW a lot of play in the hinges when pushing down on the hood, before the accident that wasn't the case, So I guess the " hit " made the hood pull the hinges up, wrecking the pivot points and geometry.. I will look for hinges hopes this makes it much better ? Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584333 Share on other sites More sharing options...
September 19, 20195 yr comment_584344 I have a couple of decent tight hinge sets left over. I went through my stash last year and threw away 2/3's of them because of excessive pivot point slop. There is just about no way to keep you hood aligned with sloppy hinges. PM me and we'll get some on the way. Edited September 19, 20195 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584344 Share on other sites More sharing options...
September 20, 20195 yr Author comment_584378 16 hours ago, zKars said: I have a couple of decent tight hinge sets left over. I went through my stash last year and threw away 2/3's of them because of excessive pivot point slop. There is just about no way to keep you hood aligned with sloppy hinges. PM me and we'll get some on the way. Okay. PM send Link to comment https://www.classiczcars.com/forums/topic/62844-240z-hood-hinges/#findComment-584378 Share on other sites More sharing options...
