L28 from 82 ZX teardown
Av8ferg
FYI, just a little bit of the gasket maker, and install quickly along the bottom edge per the book. You don't want it creating a gap by starting to setup. If I was doing over again I would use the Permatex anaerobic stuff, stays liquid (more like gel actually) until after assy, then setups up in absence of air. I doubt its a big deal but just saying that is how I would roll today after using some of the stuff. think its call 513 or something like that. I ended up using the after market with the slide in parts, no leaks (I checked it recently when I found my main seal leaking do to my poor install the 1st time.
We use 518 on battle tank chassis parts. Amazing stuff and smells great...
Okay, hopefully I won’t have to redo the job but if I do I know what I’ll use next time. Dave, I’ll run this engine on a stand like you did and fully test it while the car is getting paint and body work. If she leaks, I’ll know before install.
I am sure it will be fine, just want to let you know about the stuff, I tried it and its great.
Glad to hear you plan to use the test stand, I really like making sure everything is up to snuff, and after a big time rebuild, I can see how it would be even more important, esp if you don't do rebuilds everyday for a living. I got all hung up on that combustion gas leak in the coolant, so do that test as well.
Edited by Dave WM
