Loud noise coming from rear brakes on my 240z
jalexquijano
1 hour ago, jalexquijano said:
Any brake drum kit you would recommend?  Or should i only order the shoes?
Pull the drum on the side making the noise and look for scoring/rub wear marks on the inside of the drum.  At that time, also look to see how much material is left on the brake shoes.  Based on what you see, you MAY need to order shoes and have the drum"turned" which will resurface the inside of the drum.  Any shop that does brakes should be able to do the job - not a major event.
Dennis
Edited by psdenno
  • Who's Online   1 Member, 0 Anonymous, 510 Guests (See full list)
