I really appreciate all the input. I have read most of the links you sent at this point.
I called MSA this afternoon before I posted. They confirmed the clutch kit I ordered is designed for the shorter collar that came in the A transmission cars. I also checked the Exedy clutch website to cross reference the part numbers. The pressure plate and the clutch plate part numbers are correct for a 1970-1974.
I didn't think a 2.5mm difference would be a huge deal. I will bleed the system and see if that helps.
Thanks again,
Bill
I am starting to believe I need a new collar. The old pressure plate didn't have any "spring" to the bolts when I took it off. The new pressure plate had spring when I tightened the bolts. I was reading the fingers will suck in when the pressure plate is tightened. So the pressure plate fingers have the same height on the bench but the new one gets sucked in on the car.
I am thinking about trying the medium size one from MSA. 21-2123. It seems similar to the 280z and 280zx 2+2 on the picture above. I don't like to guess but I don't have any other ideas.
As the clutch wears in do you need to lengthen or shorten the adjusting rod on the slave cylinder? If you need to lengthen it as the clutch wears I am already maxed out with my current collar.
Edited by Pinbill
Alrighty, I am going to order the 1970-1974 collar from MSA.
Here is my theory.... They list the collar as 70-74 but there were two separate collars at that time. One for the type A and one for the type B transmission. I think all new 240z clutch kits require the type B collar. I type A collars must be NLA. I don't think there are many cars on the road with type A transmissions and their first clutch.
It makes it confusing when they say clutch kit for 70-74. It is really a clutch kit for late 71 and 72-74. No mention that early cars require a type B collar.
I hope to remember to let you know how it worked out. It is not easy to order parts for these cars. LOL.
So you bled the system and still had the problem?  Did the fork bottom out on the bellhousing hole when you tried to disengage before?  That would have been a clue.
If you haven't put it back together yet and are just going to try another collar anyway that's your prerogative.  If I read your logic right and fill in some parts you're suggesting that you have the thinnest collar, the "A" type, and need the one that's a bit thicker?  Seems reasonable.  Maybe those thick pressure plate assemblies need all of that travel.
The newer slave cylinders with the newer pressure plates don;t use the adjustable rod anymore.  Don't need it, apparently.
I have the A type collar. I also forgot to mention that I will be temporarily hooking up the transmission with the A type collar tomorrow night for some further testing. I will bleed the system then watch the slave cylinder while a helper steps on the clutch pedal. I will take a few pictures.
Its pretty cheap to get a  B collar and bearing shipped two day air from zcar depot. I feel like there is enough evidence to try it.
I didn't have help the last time I had it together so I couldn't see if the fork bottomed out on the bell housing, but the slave cylinder rod was almost fully extended it when it was adjusted right. The rubber boot was pushed to the rear of the car when the slave cylinder wasn't actuated. Definitely more clues. I should have done more testing when it was together. I was really excited to drive the car around. I just kind of freaked out and took it apart.
As the clutch wears does the rod need to be lengthened or shortened?
If the pressure plate is the same height as the old, then the existing collar would be correct as I see it.
The B collar is needed for the same pressure plate for the later transmission because the B transmission bellhousing measures at a different depth.
Also do check on slave cylinder rod movement.
I have seen hydraulic failure before with a new stronger pressure plate. Usually with very old master and slave cylinders.
One or both sometimes. They cannot hold pressure properly.
I didn't realize you need to have the plates torqued to the flywheel to get a true measurement on the fingers. My first measurements were with the pressure plates on the table and so they looked the same.
I torqued the old pressure plate and clutch to the flywheel and got 80mm +/- .5mm flywheel to fingers. I torqued the new clutch and pressure plate to the flywheel and got 70mm +/- .5mm flywheel to fingers.
It looks like I need to make up 10mm.
I ordered the collar/bearing for the 240z from Zcardepot. I am assuming its for the B transmission. It will be here in two days.
Edited by Pinbill
Collar made it the other day. It was the collar for the 240z B trans. It was higher than the collar for the A transmission. I could get the car in gear and it is better. I can get the car in gear and drive it. It shifts better when the car is moving. There is no way to get in reverse without grinding. I maxed out the pedal height and have the slave cylinder rod almost fully extended. The fork hits the transmission housing when clutch pedal is pressed. I am going to order the next size collar/ sleeve. The one for the 280zx 2+2.
I kind of lost track of your project or I would have said something.  You need to make up 20 mm, ideally, not 10. Actually 22 mm, the magic number is 92 mm.  Your old one must have been on the edge.
At least you seem to be going the right way.  Good luck.
