Posted October 9, 20195 yr comment_585410 I'm in the final stages of the resto of my early-'71, and I noticed a problem I've not seen before. When I start the car, the brake pedal drops. It really drops. If you press on it, there's no additional travel; those brakes are on. Rev it up, and they release. It didn't do this before the restoration; they worked fine back then. Why is the vacuum having so much affect on the booster? What changed? Edited October 9, 20195 yr by ByStickel Link to comment https://www.classiczcars.com/forums/topic/62967-self-applying-brakes/ Share on other sites More sharing options...
October 10, 20195 yr comment_585437 Plug the line to the brake booster and see what happens. I suspect an issue with the booster Link to comment https://www.classiczcars.com/forums/topic/62967-self-applying-brakes/#findComment-585437 Share on other sites More sharing options...
October 10, 20195 yr Author comment_585444 Thanks, Patcon! I got some advice from the interwebs, and found the problem. The 'reaction disk' has fallen out of place within the booster. Worse than that, the interior of my booster is rusty from exposure to brake fluid. I'm soaking in to try to get things apart so that I can try to reinstall the disk. Having the disk fall out is a not-uncommon problem, apparently. It happens when the master cylinder is replaced. Link to comment https://www.classiczcars.com/forums/topic/62967-self-applying-brakes/#findComment-585444 Share on other sites More sharing options...
October 10, 20195 yr comment_585461 13 hours ago, ByStickel said: Thanks, Patcon! I got some advice from the interwebs, and found the problem. The 'reaction disk' has fallen out of place within the booster. Worse than that, the interior of my booster is rusty from exposure to brake fluid. I'm soaking in to try to get things apart so that I can try to reinstall the disk. Having the disk fall out is a not-uncommon problem, apparently. It happens when the master cylinder is replaced. Yes, the disc can fall out. Normally you can shake the booster enough to get it back out of the booster. But if your booster is rusty inside from brake fluid, the diaphragm inside is split or will be shortly Link to comment https://www.classiczcars.com/forums/topic/62967-self-applying-brakes/#findComment-585461 Share on other sites More sharing options...
October 10, 20195 yr Author comment_585472 Yes, the old booster is toast. The rod that holds the disc is rusted in place. Luckily I did have a spare booster that's in good shape. I'm painting and swapping it in now. Link to comment https://www.classiczcars.com/forums/topic/62967-self-applying-brakes/#findComment-585472 Share on other sites More sharing options...
