JIDECO is the brand name. The model number is so faint on top that it cannot be read. JIDECO is stamped, the model number is printed. I thought this might be a relay for the electric fuel pump near the gas tank. It has a four prong connector. The wiper relays I have seen only have 3.
Edited by Tirnipgreen
Mine is found under the righthand side of the dash on the relay panel that mounts to the passenger kick panel.
It has part number 25230-89914 which is an intermittent wiper relay. 4 prong connector with 3 wires.
Discontinued by Nissan but I did find this https://zparts.com/index.php/product/240z-intermittent-wiper-delay-relay-25230-89914/  $75 seems a bit steep to me.
I hope that helps some.
Edited by Terrapin Z
part number correction
