Calastrophe Posted October 15, 2019 Share #1 Posted October 15, 2019 Can I hook up a belt driven 350 short blocks a/c compressor to the 260z’s AC lines? Link to comment Share on other sites More sharing options...
Dave WM Posted October 15, 2019 Share #2 Posted October 15, 2019 depends on the line fittings. A stock 260z will have flare fittings. What kind of fittings are on the compressor you want to use. The other issue will be the location of the lines, that is prob a bigger problem. Best bet would be to just have some made up that deal with the fitting and locations you have. Link to comment Share on other sites More sharing options...
cgsheen1 Posted October 16, 2019 Share #3 Posted October 16, 2019 A good hose company will be able to make whatever you need. Link to comment Share on other sites More sharing options...
