October 26, 20195 yr Author comment_586354 14 minutes ago, wheee! said: Drive it without the turbo first, then balance the cost of the turbo system against your perceived gain in performance/enjoyment. I will for a bit my main goal is to get it running. I just going to get the internals for now that can handle the boost later on. Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586354 Share on other sites More sharing options...
October 26, 20195 yr Author comment_586355 2 minutes ago, Patcon said: A normally aspirated motor is more forgiving when it comes to getting the tune right. Turbos don't tolerate lean-ness very well. A nice torquey motor in an S30 chassis is a lot of fun. These chassis are really only suitable for so much power with out a lot of work and extra metal Oh yes absolutely I agree. Here in a few years I'm going to be opening a performance shop with a dyno so I'll be doing all my own tuning and what not to include metal working. Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586355 Share on other sites More sharing options...
October 26, 20195 yr comment_586356 If you build the engine for boost now, it will be a dog normally aspirated. You will need to keep your compression low to accept boost later. A 10:1 compression NA motor with a lighter flywheel can bring just as many grins Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586356 Share on other sites More sharing options...
October 26, 20195 yr comment_586357 1 minute ago, Michael.Reitsma said: Oh yes absolutely I agree. Here in a few years I'm going to be opening a performance shop with a dyno so I'll be doing all my own tuning and what not to include metal working. Best of luck Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586357 Share on other sites More sharing options...
October 28, 20195 yr Author comment_586535 On 10/25/2019 at 5:31 PM, Patcon said: Best of luck By chance do you know roughly what the L28 is rated to horsepower wise? Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586535 Share on other sites More sharing options...
October 28, 20195 yr comment_586536 Read the Datsun Z wikipedia page. It will tell you all kinds of information, timeline etc. Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586536 Share on other sites More sharing options...
October 28, 20195 yr Author comment_586538 41 minutes ago, siteunseen said: Read the Datsun Z wikipedia page. It will tell you all kinds of information, timeline etc. Thank you. I definitely will. Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586538 Share on other sites More sharing options...
October 29, 20195 yr comment_586564 16 hours ago, Michael.Reitsma said: By chance do you know roughly what the L28 is rated to horsepower wise? We've seen stock L28E 280Z's on the dyno running from in the 90's RWHP to 110 RWHP - depending on condition. (don't be dismayed, a Z doesn't need much to make it fun to drive...) Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586564 Share on other sites More sharing options...
October 29, 20195 yr comment_586567 That's Rear Wheel Horse Power. That's very different than the advertised horsepower for new cars and such. Those are all taken at the flywheel and are significantly higher numbers Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586567 Share on other sites More sharing options...
October 29, 20195 yr Author comment_586579 8 hours ago, cgsheen1 said: We've seen stock L28E 280Z's on the dyno running from in the 90's RWHP to 110 RWHP - depending on condition. (don't be dismayed, a Z doesn't need much to make it fun to drive...) 8 hours ago, Patcon said: That's Rear Wheel Horse Power. That's very different than the advertised horsepower for new cars and such. Those are all taken at the flywheel and are significantly higher numbers I'm honestly lookin at getting around the 500 mark to the ground. Overkill? Yes absolutely I'm sure, but it's also going to be a face of a tune shop. Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586579 Share on other sites More sharing options...
October 29, 20195 yr comment_586580 So you want to swap in an RB 25/26 then. Stop now if you want to keep your L28. Max out put with a turbo won’t hit 500... Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586580 Share on other sites More sharing options...
October 29, 20195 yr comment_586589 And you'll need to strengthen the frame considerably! 500 RWHP will twist a stock body to pieces. Link to comment https://www.classiczcars.com/forums/topic/63044-what-engine-do-i-have/?&page=3#findComment-586589 Share on other sites More sharing options...
