Posted November 1, 20195 yr comment_586757 I opened a diff I just got with a lot of parts and it has the following stamped markings on the ring gear: 35 X A C 5 - 11 Anyone have a clue as to the ratio? Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/ Share on other sites More sharing options...
November 1, 20195 yr comment_586764 35/11 = 3.18 That would be lovely for highway cruising. Are you selling it? Edited November 1, 20195 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586764 Share on other sites More sharing options...
November 1, 20195 yr Author comment_586772 I would but what car did it come in? Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586772 Share on other sites More sharing options...
November 2, 20195 yr comment_586777 I could only find TonyD mention on HybridZ about max velocity and differential. He may know: I can't find any else. yet Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586777 Share on other sites More sharing options...
November 2, 20195 yr comment_586804 Doubt you can discern any meaning from those numbers. The ratio will be in xx:xx format, e.g. 39:10 which means a 3.9 ratio. Take another look at the ring gear. Edited November 2, 20195 yr by LeonV Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586804 Share on other sites More sharing options...
November 2, 20195 yr Author comment_586805 I have looked all over that ring gear and have diffs from 3:34 to 5:38 (hill climb or stump puller). Those are the only markings. Edited November 2, 20195 yr by gnosez Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586805 Share on other sites More sharing options...
November 2, 20195 yr comment_586807 Manually count the crownwheel teeth and pinion teeth to be sure. As far as I am aware (and I just checked the Nissan Sports 'Final Drive & Limited Slip' factory bible to be sure) only the R200 was available with a 3.1 (actually 3.151) ratio, with a 41 tooth crownwheel and 11 tooth pinion. Lowest numerical ratio on the R180 was the 3.364. Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586807 Share on other sites More sharing options...
November 2, 20195 yr comment_586813 Could it be from a Datsun truck or Subaru? Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586813 Share on other sites More sharing options...
November 2, 20195 yr comment_586817 Why are there no pictures? Has anyone ever made aftermarket gears for the R180's? Pretty common for other manufacturers. Maybe it's an aftermarket gear set. Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586817 Share on other sites More sharing options...
November 2, 20195 yr comment_586818 On 11/2/2019 at 11:37 PM, Zed Head said: Has anyone ever made aftermarket gears for the R180's? Pretty common for other manufacturers. Maybe it's an aftermarket gear set. Kameari Engine Works in Japan manufactured 3.1, 4.875 and 5.1 CWP sets for the R200 when the OEM supplies dried up. Nothing for the R180, as far as I am aware. Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586818 Share on other sites More sharing options...
November 3, 20195 yr comment_586819 You know, you could manually check the ratio by counting rotations to see if it lines up with Philips 3.18 Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586819 Share on other sites More sharing options...
November 3, 20195 yr comment_586822 Forklift? I only know (heard/read) that L6's were used in some. Don't know about axles. https://www.leavittmachinery.com/parts/by-parts-type/rockwell-axle-parts Link to comment https://www.classiczcars.com/forums/topic/63084-r180-identification/#findComment-586822 Share on other sites More sharing options...
