R180 Identification
gnosez
Manually count the crownwheel teeth and pinion teeth to be sure.
As far as I am aware (and I just checked the Nissan Sports 'Final Drive & Limited Slip' factory bible to be sure) only the R200 was available with a 3.1 (actually 3.151) ratio, with a 41 tooth crownwheel and 11 tooth pinion. Lowest numerical ratio on the R180 was the 3.364.
6 minutes ago, Zed Head said:
Has anyone ever made aftermarket gears for the R180's?  Pretty common for other manufacturers.  Maybe it's an aftermarket gear set.
Kameari Engine Works in Japan manufactured 3.1, 4.875 and 5.1 CWP sets for the R200 when the OEM supplies dried up. Nothing for the R180, as far as I am aware.
