Restoration of BringaTrailer 240z - HLS30-35883
inline6
1 hour ago, CanTechZ said:
Here's a picture of the screws that held down those strips on my '70. They are round head type 4mm thread OD x 12 mm long. There appear to maybe have had blackened heads, some evidence on a few of mine.
Same screws on mine as well.
Posted (edited)
Not that long ago, I got the steering column in the car.  Here are some reference hardware pics.  Note that in the first two pics I have the wrong flat and lock washers.  The ID is too large.
Can anyone confirm that this is the correct orientation of the bolts and nuts?  I didn't recall exactly how they were originally and couldn't find any reference pictures.  I have two bolts going upwards and two going downwards.  The bolt heads and the nuts seem to be a bit lower profile than standard, and the way I have them installed seems to be the most logical.
Edited by inline6
Posted (edited)
I couldn't find the original screws for the threshold plate, so I got these from Belmetric - some of the only non-original hardware anywhere on this car!  🙂
I have looked for many years for a 240z rear view mirror that doesn't show signs of corrosion on the edge of the glass, but haven't found any.  I am thankful that @zspert sells an excellent reproduction:
Next step for the upholstery cardboard was to coat it in a rubber coating to keep moisture from causing it to lose its rigidity over time.
These are ready to glue into place now.
Speaking of gluing, I finished gluing the rear hatch main seal in place this weekend.  I again used the yellow "landau" contact adhesive.  I glued the four corners in place first.  This seal is a bit small for the opening and requires stretching.  So, gluing the corners first allowed me to put sufficient stretch into the rest of the seal.  Then, it was a matter of using the acid brush to apply the adhesive in the remaining areas.  This adhesive sets up in under one minute, and is super strong.  I found that it was best to work in sections that were only about 18" in length.  I would apply adhesive with an acid brush on the weld flange as well as the backside of the weather strip, then wait about one minute.  As soon as I put the two together, it sticks, and goes nowhere.  Great stuff to work with.
I started to install the fuel hose in the engine compartment.  Before doing so, I checked to see if the carburetors had inline fuel filter screens.  The front carb did not, and the back carb did.  I installed new ones.  I have to check that the floats are set correctly, so I elected to hold off on installing the hoses that go from the fuel rail to the float chambers.  I did install the hose to and from the fuel filter.  Hose is cloth covered; the closest thing I could find to original.
Can anyone confirm the hose clamps I am using here are correct?  I think that the clamps at the filter are supposed to be spring clip type... while the connections at the hard line and fuel pump inlet are supposed to be the zinc plated hose clamps as seen here:
I also got all the bumper pieces packaged up.  I will be sending them to Tri-City plating to get them redone.
Edited by inline6
Posted (edited)
Thanks for this.
That is the most accurate engine and engine compartment I have ever seen.  I especially like the plating, and the finish on the SU domes and valve cover.  While my plating is nice, I wish it was more authentic, like yours.  Incredible.
Edited by inline6
