2 hours ago, inline6 said:
I found out that the water pump (one of the few parts that I did not replace) was weeping coolant.
Well, at least it should be a simple fix.
And I did like emccallum did... After a the initial 15 second fire-ups, when I did add liquid, I added straight distilled water. No antifreeze. Ran it like that for a little while to check for leaks. Rad cap off. Then, next step was rad cap on and let it build pressure. Then once I was convinced it would hold pressure, I drained all that out and started fresh with 50/50 distilled/anti-freeze.
This evening, I examined the needle and seat from the rear carburetor.  If found some residue on needle.  When I used a wire brush to clean it up and examined the needle (it is metal) closely, I could see a light wear ring.  I found two spares I have had for decades and examined them.  The needle portion appears to be made out of a hard rubber.  I may have bought them new to swap out in my carbs that I used to run on my track car, but never did.  Can't remember now.  Anyway, they looked pretty much like they were unused.  So, I swapped those into the front and rear carbs and reset the float levels using the "wet method".  By siting the fuel in a clear tube, they are both set perfectly now.
After that, disengaged the balance screw, and set each carb throttle adjusting screw so that I saw the lever move.  I set each at about 2 turns in.  Then, I turned the key and the engine came to life.  Within a couple of minutes, I had the front and rear carbs running on just the carburetor throttle adjusting screws. I turned in the auxiliary shaft adjusting screw to operate the linkage and then adjusted the balance screw to get the air flow the same between the carbs.  At that point, I was going check the timing and start adjusting idle speed, but the clatter from the valves was too much and I began to be concerned.
So, I decided to shut it off and pull the valve cover.  Upon doing so, I was pleased to see no obvious damage to the cam lobes (I had a couple of bad experiences with new cams in my track car).  I started checking valve clearances.  Just about every one of them did not have enough clearance.  I went through and made minor adjustments until - you know it... the last one.  For that one, I ran the 14 mm adjustment screw all the way down, but I ran out of adjustment and still couldn't get a .20 mm feeler gauge (it is an intake valve) in between the cam base circle and the rocker pad.  So, I pulled the rocker and lash pad.  The wipe pattern is not centered and nearly off the front edge.
Guess who is going to have to pull all the rockers and potentially change out some lash pads?
Edited by inline6
When I run my adjusters all the way down, I have LOTS of clearance. Like almost enough to actually pull the rocker out without even compressing the valve spring. Almost, but not quite. Point is... Something really doesn't seem right. I bet I could install the thickest lash pad ever created and STILL have clearance when my adjuster is run all the way down.
Are you double dog sure that everything else is as expected? Valve stem lengths are correct? Valve seat depth is as expected? Head not cut on the top side to clean it up? Something?
And about the carb float valves... I think they switched to the rubber tipped valves in 1972 "improving sealing performance".
Yeah, something really isn't right.  I have snapped a bunch of pictures and talked with my engine builder, who did the work on this head.  The current hypothesis is that the SI Stainless valves I bought are too long.   The installed heights are still visible in black marker on the cyl. head:
1.787" is a lot more than the specification paperwork from Iskenderian (1.700"):
The lash cap I pulled out with the one rocker arm I removed last night is .117" and about 3 tenths.   Stock is .118".
But the "kit" I ordered from Iskenderian has .175" lash pads, (part LC175 - is .175" thick - I looked it up on their site):
The retainers currently installed look like the Isky ones.  The depth to accommodate the lash pad is notable.  Comparing to another exhaust valve which has not had the rocker and lash pad removed, the lash pad (I am assuming also .118"/stock) is "buried" in the retainer.
So, the theory right now is that SI Stainless valves are taller than the stock valves (4.620").
I think I will have to pull the head.
My engine builder is a great guy and he has provided me with so much value over the years.  In this instance, I should have checked the wipe pattern before installed the head, but I did not.
As far as I can tell, no damage has been done.  So, I think I have been fortunate here.
Just my opinion, but I’d work with lash pads and adjustment before I’d pull that head. This is my Stroker with Isky Stage III cam and the same valve springs as you. .160 lash pads centered my wipe patterns. Check my valve numbers….zoom in to read em. Definitely check wipe patterns before starting.
Edited by Diseazd
15 minutes ago, inline6 said:
Ok.  Yeah, I am going to pull all the rockers and look at wipe patterns, and measure lash cap thicknesses first.
You can remove all rockers but one. Remove all spark plugs. Turn the engine over by hand. Get the right lash pad to center the wipe pattern on that rocker and the rest should be close.
Edited by Diseazd
Might be just me Edit _ I see Diseazd suggested starting with patterns.  So not just me.  Anyway, more observing and measuring seems in order  ...but I'd do the wipe pattern before doing anything else.  If all of the patterns are good except the last one then you know you have a one valve problem.  What can you fix on the other eleven if lash and pattern are good?
Besides that you meed a starting point.  The wipe pattern gives you that, telling you if you need taller or shorter pads.  Might be a simpler problem than it seems.  Good luck.
Edited by Zed Head
Is the issue solvable with a lash pad change? What I mean is... The lash is too tight. Even with the adjuster all the way down. That clearly means a thinner lash pad is required. But the wipe pattern is almost off the end of the hardened pad.
What happens to the wipe pattern when the lash pad thickness is reduced? I've never messed with it in any great detail. Does a thinner pad move the contact patch towards the adjuster end of the rocker, or towards the valve tip end?
If a thinner lash pad moves the contact patch towards the valve tip, then this issue cannot be solved with a lash pad change.
