May 25, 200321 yr comment_38761 Sorry, I went offline for a while.I have the part numbers on one of the original Japanese Factory Parts Catalogues, and they sometimes have good illustrations in them. I have a particular interest in the Japanese home-market cars, and especially the Sports Option and Competition parts and their dedicated lists.I could try to scan a picture of the Fog Lamps and their brackets if it would be any help?Alan T. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38761 Share on other sites More sharing options...
May 25, 200321 yr comment_38764 I copied off these two shots from the archived forums. One is about the interior switches, and the second is a front shot of a license plate I would like to have. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38764 Share on other sites More sharing options...
May 25, 200321 yr comment_38765 Oops, got it backwards. Switches - #9 is early 70 and #10 probably 71 on. I'm going to write a book about the parts differences. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38765 Share on other sites More sharing options...
May 25, 200321 yr comment_38768 I posted the originals of both of those shots on the forums, when we were discussing switches and Fog Lamps.What do you mean about the license plate? You want the original plate or the original photo?Alan T. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38768 Share on other sites More sharing options...
May 25, 200321 yr comment_38770 I think the plate looks real good between those snazzy driving lights! Would like to talk to you about your literature collection. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38770 Share on other sites More sharing options...
May 25, 200321 yr comment_38772 Just did a little housework in my PM box. Should be room to PM me now.Please bear in mind that its 2.30am here in London and I'm getting a bit sleepy!Alan T. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38772 Share on other sites More sharing options...
May 26, 200321 yr comment_38834 Mike:The Fog Lamp Wiring that you are looking for is in the harness.In the Front Wiring Harness, between the two Headlight Connectors, you should find a pair of bullet connectors, one on each side between the Horn Wires and the Headlight Wires.They will be a Red and Black Wire Pair. These are the ones that go to your Fog Lamps, the Black being Ground. If you have the single wire Fog Lamps that can be found now, then connect the black wire to ground, as that is what it is.Inside the Dash Wiring, you will find a Red and Red / Green pair of wires going to a 2 wire "T" connector (i.e. the spade lugs inside form a "T"). That is where you hook up your switch. The switch only CLOSES that circuit, i.e. you could connect the two wires and the lights would turn on.Power is fed to the Fog Lamps from the Tail Lamp / Side Marker Light circuit that runs through the Combination Light Switch. i.e. you must have the light switch turned on for the Fog Lamps to light.I wired my fog lamps through this circuit and they seem to work fine.Enrique Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38834 Share on other sites More sharing options...
May 26, 200321 yr Author comment_38841 Excellent, ES, that's what I'm looking for! Thanks. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-38841 Share on other sites More sharing options...
April 5, 201311 yr comment_419707 So...It's 10 Years later since this thred was used and Now I'm wondering if there are any sources for these fog light kits being reproduced for 1972 240Zs. Anyone??? Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-419707 Share on other sites More sharing options...
February 20Feb 20 comment_674732 Resurrection!!! https://jdm-car-parts.com/products/original-style-fog-lamp-set-for-jdm-fairlady-z-datsun-240z-260z-280z-510-roadster?srsltid=AfmBOoq9Z4T801ioQzmLJnAbk5VItXD-5LYHbUtRaHKJH_TFZvNyk7Os Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-674732 Share on other sites More sharing options...
February 21Feb 21 comment_674738 Resurrection is better than speculation. Â Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-674738 Share on other sites More sharing options...
February 21Feb 21 comment_674739 They look remarkedly similar to the ones I bought at Kmart in the early 80s when I lived in rural Texas. They might still be stowed away somewhere in my shop. Link to comment https://www.classiczcars.com/forums/topic/6311-240z-pre-wired-driving-lights/?&page=2#findComment-674739 Share on other sites More sharing options...
