Email logins are now active ×
Different ignition
Stick figure
I've had my 83 zx in the driveway for over a year, haven't driven it on the road yet, more rust than car, but ready to start if I can figure out my problem. It runs and will move but before I start, I want to do away with the fuel injection and all the electronics. I found a 4 barrel intake, expensive but worth it to me. What should I do about the electronic ignition? I was thinking about points, but can't find a points distributor anywhere online. Any help will be greatly appreciated. I was going to swap out the 6 for a 350 but I've grown attached to the inline 6. I've looked everywhere for info on this and I'm just about ready to give up.
12 minutes ago, SteveJ said:
He would need the 240Z distributor mount.
True.  He could modify his also, I'd guess.  It's the clamping screw that's the issue.
Keeping the ZX distributor is the easiest.  It's not connected the to the EFI system.  You can keep it and run carbs.
I was responding to the question as asked.
That's what I would do. Keep your distributor with the carb. That's what we've all done but with dual carbs. Should be the same.
The '83 matcbox has those extra 2 terminals on them. I think that's the e12-92 or something. I've read the extras are for the crank sensor but cant confirm. I also read you can leave that plug open. Another unconfirmed answer but the info is out there on the www.
I'm pretty sure the distributor runs off the computer
I don't believe there is any computer controlled timing on that car. I might be wrong, but if the computer is involved, it is only for basic power. The ignition is still pretty simple on the 83 cars
  • Who's Online   1 Member, 0 Anonymous, 570 Guests (See full list)
