Posted November 11, 20195 yr comment_587399 I have a 1983 280zx turbo motor and there is a sensor on the passenger side left of the oil filter and between the oil filter and the oil dip stick. now on the other side of the oil filter is the oil pressure sensor but I do not know what this one is . it reads normal open with a ohm meter and has 2 electrical connections on it and screws into the block. I am thinking it might be temperature and if so if I can use it for controlling my electric cooling fan. thanks Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/ Share on other sites More sharing options...
November 11, 20195 yr comment_587402 think its a knock sensor Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/#findComment-587402 Share on other sites More sharing options...
November 11, 20195 yr Author comment_587408 yes Dave I am not sure what this is also, if I can not use it I would like to plug it up if I can find what the thread size is ? Edited November 11, 20195 yr by kully 560 Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/#findComment-587408 Share on other sites More sharing options...
November 11, 20195 yr comment_587415 It screws into the block, or the head? You got a pic? Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/#findComment-587415 Share on other sites More sharing options...
November 11, 20195 yr comment_587417 From page 62 of section EFEC: Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/#findComment-587417 Share on other sites More sharing options...
November 11, 20195 yr Author comment_587436 yes Steve that is it thanks I guess I will remove it , looks like I can not use it . do you know if there is fluid behind it being it is a knock sensor ? do I need a plug or can I just remove it ? thanks kully Edited November 11, 20195 yr by kully 560 Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/#findComment-587436 Share on other sites More sharing options...
November 11, 20195 yr comment_587454 I suspect its in the water jacket Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/#findComment-587454 Share on other sites More sharing options...
November 11, 20195 yr Author comment_587461 I think the same thing but I do not want to remove it with be sure as I do not have a plug for it ! Link to comment https://www.classiczcars.com/forums/topic/63137-sensor/#findComment-587461 Share on other sites More sharing options...
