Distributer Shaft Play
Zpeed
ahhhh, that ain't around the corner from Oakleigh!
You won't have any problems changing over, They didn't import duel points into Australia [as far as I'm aware].
Just remember the order of the leads and simply change the distributor over.
cool thanks
do you know if its no problem, putting the early skyline L24E eletronic distributers onto the Z... i would be thinking the are the same as the 79 280zx, i can use the 82-80 module from the one i have now and put it on there if its not the right module
well i put on a L24E distributer, i had to change the timing braket part, to the 280zx one, as it was to tall, and wouldn't let the distributer fit in and hold....
but otherwise the car is perfect now, runs like new, and is fantastic... thanks alot for ur guys help.. it helped me out alot
  • Who's Online   0 Members, 0 Anonymous, 498 Guests (See full list)
