Posted November 17, 20195 yr comment_587777 I have some time on my hands so I've started coloring in a wiring diagram for a 260z. Before I sink too much time into this, has anyone come across a COLOR 260z wiring diagram? Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/ Share on other sites More sharing options...
November 17, 20195 yr comment_587788 I've not seen one for the 260. What tool would you be using to create the diagram? There's a great one for the 77 done in AutoCAD. Would it save you work to start from that and modify it for the 260, or would it be just as easy to start from scratch? Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-587788 Share on other sites More sharing options...
November 17, 20195 yr Author comment_587794 I'm using Inkscape, an open source drawing program similar to Adobe Illustrator. The wires are grouped in layers by system (e.g. lighting, ignition) but I haven't figured out yet how to keep the layers separate when I export them to acrobat. wire drawing pg1.pdf I have tomorrow night and a couple days next weekend with nothing to do and I hope to have it 75% completed by then unless it's already been done by someone. The wires are colored according to the diagram's designation and I use a dashed colored line to designate the secondary wire color so LY would be a blue line with a yellow dash as an example. Edited November 17, 20195 yr by Jeff Berk Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-587794 Share on other sites More sharing options...
November 17, 20195 yr comment_587814 @Jeff Berk @Kurbycar32 @SteveJ Since y'all have 260's, and I have a 1977 280 ( which there is an available color diagram ) anyone want to swap cars and titles so i have a NEED to make a color diagram for a 260z? Just a thought. I laugh at my thoughts. Coincidentally, I have a few free days coming up myself. Wayne Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-587814 Share on other sites More sharing options...
November 17, 20195 yr comment_587816 4 minutes ago, wal280z said: @Jeff Berk @Kurbycar32 @SteveJ Since y'all have 260's, and I have a 1977 280 ( which there is an available color diagram ) anyone want to swap cars and titles so i have a NEED to make a color diagram for a 260z? Just a thought. I laugh at my thoughts. Coincidentally, I have a few free days coming up myself. Wayne I could do it in AutoCAD, but I just haven't decided I needed a color version. Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-587816 Share on other sites More sharing options...
November 17, 20195 yr comment_587817 Unfortunately I need to sell mine. I just finished getting mine spiffed up and ready to go Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-587817 Share on other sites More sharing options...
November 17, 20195 yr comment_587818 1 minute ago, SteveJ said: I could do it in AutoCAD, but I just haven't decided I needed a color version. You may not need a color version, but ya can't just think about yourself. The need has been shown. Take one for the team and publish a color one already/ Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-587818 Share on other sites More sharing options...
January 2, 20205 yr Author comment_590252 The wiring diagram is taking longer than I thought but here's where I'm at so far. Feel free to poke holes in it as I'm working through the remaining wires and fixing errors. The wires are grouped by sub-system but for now that feature gets stripped off during the conversion to pdf. wire drawing pg3.pdf wire drawing pg4.pdf wire drawing pg2.pdf wire drawing pg1.pdf Edited January 2, 20205 yr by Jeff Berk Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-590252 Share on other sites More sharing options...
January 2, 20205 yr comment_590258 On 11/17/2019 at 11:40 AM, Jeff Berk said: I'm using Inkscape, an open source drawing program similar to Adobe Illustrator. The wires are grouped in layers by system (e.g. lighting, ignition) but I haven't figured out yet how to keep the layers separate when I export them to acrobat. wire drawing pg1.pdf You would probably have to make each layer a separate .pdf. Extra work, but It would make things easier to trace. Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-590258 Share on other sites More sharing options...
January 3, 20205 yr Author comment_590281 The layer issue is that I recently lost access to the current version of Adobe Acrobat Pro. I can create separate pdf's of each layer using the software I have on hand but as of yet, I'm unable to then combine them into a single pdf while maintaining separate layers without Adobe Pro. I'm looking into some work arounds. Link to comment https://www.classiczcars.com/forums/topic/63162-260z-color-wiring-diagram/#findComment-590281 Share on other sites More sharing options...
