June 27, 20213 yr comment_624145 11 hours ago, grannyknot said: The engine won't start by turning the key, I have to turn the key to ON and use a remote hand switch connected to the starter? Sounds like the keylock switches are not wired correct, on "START" the fuelpump is activated? (as on "ON" ?) and is the ignition on "START" as it IS on "ON"? (Obviously you got ignition on ON.. as it runs..) Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624145 Share on other sites More sharing options...
June 27, 20213 yr Author comment_624179 Haven't figured out the key/starter problem yet but had it running today and while the engine is warming up and the revs are normal and steady if I unplug the MAF the revs go anther 400 rpm higher, plug the MAF back in and they go back to normal, once the engine starts cycling unplugging the MAF makes no difference. Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624179 Share on other sites More sharing options...
June 27, 20213 yr comment_624182 It does sound like a mixture problem. Any chance you have an air-fuel ratio meter handy? 🤓 I could envision a scenario where the mixture correction data lags the engine's response time, though I'm not sure at the moment how to correct it. Is it fitted with a mass airflow sensor or an airflow meter? Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624182 Share on other sites More sharing options...
June 27, 20213 yr Author comment_624185 15 minutes ago, ETI4K said: It does sound like a mixture problem. Any chance you have an air-fuel ratio meter handy? 🤓 I could envision a scenario where the mixture correction data lags the engine's response time, though I'm not sure at the moment how to correct it. Is it fitted with a mass airflow sensor or an airflow meter? It has a MAF but it came with the engine so I have no idea if it works or not, unplugging the MAF changes the rpm when at idle so I'm assuming that it works. On 6/26/2021 at 5:26 PM, siteunseen said: My d21 pickup did that too. It was the vacuum hoses that hook up right beside each other, 4 side by side if I remember right. I removed all the pollution control vacuum lines when I rebuilt the engine, the only vacuum line left goes to the fuel regulator, I'm pretty sure there are no vacuum leaks as I've very careful to eliminate that possibility on reassembly. 13 hours ago, dutchzcarguy said: Sounds like the keylock switches are not wired correct, on "START" the fuelpump is activated? (as on "ON" ?) and is the ignition on "START" as it IS on "ON"? (Obviously you got ignition on ON.. as it runs..) Fuel pump is working while cranking. I disassembled the ignition switch today, cleaned and sanded the contacts, it seems to be working fine. I'm using a canam relay/fuse box to handle the fuel pump, ECCS and RUN, I did notice the RUN circuit isn't energized when the key is in the start position but is on in the ON position. In a pinch I guess I could run a momentary switch and dash mount it as a start button but I would rather solve the wiring problem first. Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624185 Share on other sites More sharing options...
July 8, 20213 yr Author comment_624740 Have solved some problems and acquired others, fuel pump died on me so waiting a new to arrive soon, in the mean time trying to finish the rest of the car. I had a set of 240z sunvisors on the self so tried them in the 510, they fit! And fit perfectly, as if they might have been an possible option for Nissan. Spoiler and front bumper are on, brakes and clutch are bled, the rear window is done, carpet kit is in (those wrinkles are not in the finished job). Finished the SS threshold plates and installed the seats today, just need a fuel pump now. Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624740 Share on other sites More sharing options...
July 9, 20213 yr comment_624755 I hope to see this when it is complete. What a great build. Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624755 Share on other sites More sharing options...
July 9, 20213 yr comment_624769 Mazda (Rotary cars) seats? Don't know if you told us already but i see the rotor in the seat top haha 🙂 Looks/fits good! Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624769 Share on other sites More sharing options...
July 9, 20213 yr Author comment_624813 10 hours ago, dutchzcarguy said: Mazda (Rotary cars) seats? Don't know if you told us already but i see the rotor in the seat top haha 🙂 Looks/fits good! Oh yeah they are comfy, RX8 Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-624813 Share on other sites More sharing options...
July 17, 20213 yr Author Popular Post comment_625255 I got her running well enough to take it for its first drive, fun little car, went for a blast up my back road. A few rattles and vibrations I have to hunt down and need a new filler hose so ordered that today. The car is filthy from sitting in the shop since the paint job but you can get the idea of what it will look like when she's all shiny again, very pleased with the height, just where I like it. Don't want to look like a boy racer. Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-625255 Share on other sites More sharing options...
July 18, 20213 yr comment_625264 Very nice. The word, 'hooligan' comes to mind. Make sure you read up on the new revisions to the Ontario stunt driving laws . Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-625264 Share on other sites More sharing options...
July 18, 20213 yr comment_625295 Your car looks great. What a blast it'd be to drive it. The 510s are great cars. Did you tee into the filtered air boot, or is it off the shelf? Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-625295 Share on other sites More sharing options...
July 18, 20213 yr Author comment_625298 1 hour ago, ETI4K said: Did you tee into the filtered air boot, or is it off the shelf? That is an aftermarket 90 degree silicone elbow that punched a hole in for the IACV Link to comment https://www.classiczcars.com/forums/topic/63170-the-blue-510/?&page=11#findComment-625298 Share on other sites More sharing options...
