Dave WM Posted December 2, 2019 Share #25 Posted December 2, 2019 can you tell if the shift rod seems fully seated in the detent? IIRC after shifting you should feel a tiny bit of fore/aft play in the shifter, if not then perhaps the rod had not seated into a detent. in other words the shifter ball is firmly pressing inside the socket after engaging, not good. Link to comment Share on other sites More sharing options...
Zed Head Posted December 2, 2019 Share #26 Posted December 2, 2019 The bushings need to be tight also. If they're destroyed you lose a lot of travel. Link to comment Share on other sites More sharing options...
zKars Posted December 4, 2019 Author Share #27 Posted December 4, 2019 (edited) No big surprise here, but the two japanese sources that claimed to have new shift forks have said NLA and returned my money. Poop. Now I need someone with a trashed 5 speed that I can scavenge for parts or this entire trans is trash or will be a donor for other parts. Edited December 4, 2019 by zKars Link to comment Share on other sites More sharing options...
Zed Head Posted December 4, 2019 Share #28 Posted December 4, 2019 carpartsmanual says the 4 speed forks will work, if you get the right 4 speed. It also says that you might get the wrong 5 speed parts, and be in the same pickle. I'm repeating myself, but just in case you didn't look at the link. It's not the number of gears, it's the part number. Link to comment Share on other sites More sharing options...
dutchzcarguy Posted December 4, 2019 Share #29 Posted December 4, 2019 On 11/30/2019 at 3:24 AM, zKars said: I'm in the process of rebuilding a one, maybe two, or three, not sure, FC5W71B transmissions. zKars, could you rename this thread to the right name of gearbox because no one can find it back later on.. FS5W71B Thanks! Link to comment Share on other sites More sharing options...
240260280 Posted December 4, 2019 Share #30 Posted December 4, 2019 Jim, I had partially disassembled 5 speed that used to be in the basement but is now somewhere in the Z barn. I'll try to find it the next time I am there. Link to comment Share on other sites More sharing options...
madkaw Posted December 4, 2019 Share #31 Posted December 4, 2019 Not to disparage this thread , but that’s why recently I opted for a 71C for my 83 truck. You can t find B’s because they don’t last, parts are hard to come by , and have a weak counter bearing . C kits are cheaper and more abundant and they don’t break as much because they are stronger . Link to comment Share on other sites More sharing options...
zKars Posted December 4, 2019 Author Share #32 Posted December 4, 2019 While I agree with Madkaw's statement about C types, (I have one going in my 510 shortly), they are not always as available as I'd like. They also need shifter location in the console adjustment, and shortened drive shafts, and engine mount tweaking, so not all will choose them. Given the reduced cost now of rebuilding a B type myself now vs getting someone else to do it, I will keep all the B's in my life alive until all the shift forks give out. 3 Link to comment Share on other sites More sharing options...
zKars Posted December 4, 2019 Author Share #33 Posted December 4, 2019 4 hours ago, dutchzcarguy said: zKars, could you rename this thread to the right name of gearbox because no one can find it back later on.. FS5W71B Thanks! Done. Didn't know you can do that! Just click and hold on the title text, and it turns into an edit field. 1 Link to comment Share on other sites More sharing options...
Zed Head Posted December 4, 2019 Share #34 Posted December 4, 2019 I don't know what this company does but they have the part numbers. 32805-E9001 https://mmerlinn.com/catalog/dox_angel/dt_w7b/dtw7bp23.htm 1 Link to comment Share on other sites More sharing options...
Zed Head Posted December 4, 2019 Share #35 Posted December 4, 2019 And, it looks like other models used the same parts. No surprise, but expands the possibilities. Also says that the part number has been superceded by 32805-Q0101. IF the E9001 is the right fork. Could be the E9000. https://www.nissanpartsdeal.com/oem-nissan-720_pickup-shift_fork.html 1 Link to comment Share on other sites More sharing options...
Zed Head Posted December 4, 2019 Share #36 Posted December 4, 2019 More https://www.nissanpartsdeal.com/parts-list/1981-nissan-datsun_810/power_train/transmission_shift_control.html Link to comment Share on other sites More sharing options...
