Zed Head Posted December 13, 2020 Share #205 Posted December 13, 2020 6 hours ago, dutchzcarguy said: I see there is stated a 280zx has a C type box? where i know it's a B.. A 280zx has never had a Fs5W71C always a B i could be wrong ofcourse. So they (also) don't know it all.. There is a bad database out there that somebody created for the Z car transmission parts. Apparently everyone uses it because the same errors are shown by everybody. It's kind of illuminating about how the car parts market works. There is another about CV axles for the 240Z. 1 1 Link to comment Share on other sites More sharing options...
zKars Posted December 14, 2020 Author Share #206 Posted December 14, 2020 On 12/12/2020 at 3:27 PM, zKars said: Then that's a bad thing. It is the correct design..... Sorry Let me see if I have a 23 tooth reverse idler... Nope, sorry. Link to comment Share on other sites More sharing options...
zKars Posted June 17, 2021 Author Share #207 Posted June 17, 2021 (edited) Speaking of center finders, here is a new cool tool of that ilk that appeared on the ol’ FB feed today. https://www.centerquic.com/?fbclid=IwAR2qYZtaqWD0fYPMFBh5QQUuivk6HbW9_4nqL0SCk1PHutx-C6B4nT2LYQ8_aem_AZBxVPZMyQBRqlSeY_76rQlEL4s4Lbpu5c3QIw0Efp9DDIcEwJj3dOuf_5xhVlkR5e5Yxr72CvqgWUDoomgqObEK5WAORsFvh2zrzCo13nXQgt05YdcFxIWGmVjZMtXM92Y $168 USD. To click or not to click “Purchase now”… Edited June 17, 2021 by zKars 1 Link to comment Share on other sites More sharing options...
dutchzcarguy Posted June 18, 2021 Share #208 Posted June 18, 2021 17 hours ago, zKars said: $168 USD. To click or not to click “Purchase now”… not.. They make it for probably 15 bucks or less.. so to expensive. i use my eyes.. to look for the center haha.. Link to comment Share on other sites More sharing options...
Matthew Abate Posted January 25, 2022 Share #209 Posted January 25, 2022 (edited) On 12/15/2019 at 7:04 PM, zKars said: BUT this sad little truck trans IS a donor for my worn out 1/2 shift fork! They are identickle! Took it apart today, and it's in perfect shape. Gear ratio's are interesting. Being a truck, first is a bit of a stump puller. 1 3.592 2 2.246 3 1.415 4 1 5 0.813 Sorry to resurrect an old post from a semi-old thread, but I’m curious what makes you say the first gear ratio on the truck transmission is a stump puller. It’s identical to the stock 4-speed ratio (as are 2, 3, and 4), according to ZHome. I’m concerned about this as this is the transmission I’m intending to put into my ‘73 (a 1980 720 5-speed with case #1). Edited January 25, 2022 by Matthew Abate Link to comment Share on other sites More sharing options...
zKars Posted January 26, 2022 Author Share #210 Posted January 26, 2022 1 hour ago, Matthew Abate said: Sorry to resurrect an old post from a semi-old thread, but I’m curious what makes you say the first gear ratio on the truck transmission is a stump puller. It’s identical to the stock 4-speed ratio (as are 2, 3, and 4), according to ZHome. I’m concerned about this as this is the transmission I’m intending to put into my ‘73 (a 1980 720 5-speed with case #1). Well, I stand corrected. And thinking about it after having driven this trans for many miles, first is not as low as I thought. Thanks for setting that straight Link to comment Share on other sites More sharing options...
Matthew Abate Posted January 26, 2022 Share #211 Posted January 26, 2022 Oh thank bejeezus! I was having a mild panic attack about having put a lot of effort and money into something that was maybe going to be a boat anchor. Link to comment Share on other sites More sharing options...
