Guys,
     my car is in the process of getting most of the interior parts reinstalled in the vehicle.  When i purchased it, the interior was basically stripped and i have been piecing it back together. MY question is which piece should i have in the location directly in front of the shiftier.
is it this?
or this?
or this one?
i believe it is the first pic because i do not have a series one car.  Vin pick below:
https://www.classiczcars.com/forums/topic/63281-center-console-1971-question/
Like this no?  i have the cigarette lighter in the dash.  I didn't believe there was two 12v ports.
ive searched pics but there is a lot of discrepancies on the inner webs with cars and titles
Interesting, maybe someone swapped dashes? Do your vins match everywhere. My interior is set up like the pics here:
https://hymanltd.com/vehicles/5796-1971-datsun-240z-coupe/
My 4/71 Z which I've owned since new has the ash tray and lighter in the center console like the one pictured above.  No lighter in the dash.  You likely have a replacement dash from a later Z.
Dennis
Up to 8.71 the console with the ashtray was installed in the 240z.
After that was the other console version with the switch plate.
Another way to be absolutely sure: whatever one fits in your vehicle as they are not interchangeable.
20 minutes ago, clocatelli said:
i think i got it.  the below pic is where i need to be.  What is the top switch suppose to do circled below:
I think someone added that, as I'm not aware of any Z from the factory having two switches there. It's normally either a blank, or a cig lighter. I believe only 72-73 Zs had the cog lighter, and your '71 should have had a blank.
Edited by rturbo 930
