280z 78 Wont idle, Running Rich, out of ideas.
Cyrillink
Hey Team
I have spent a lot of time on this  forum and i want to say thank you all so much this is an incredible community.
I have hit a brick wall and looking for a little help.
Background story; I'm helping a friend of mine fix his 280z with 30,000 miles on it all original. Car has been garage kept all its life. Really really well taken care of. Apparently some one A-hole mechanic tried before me and failed miserably and i don't know what he/she messed up or touched. After them the car didn't even start. Fixed that issue. (FACE PALM) ?‍♂️
When you try to start the car it tries to start but never does on its own. If you give it gas than the car starts but it is runs rough(motor shaking). Have to keep the gas paddle pressed in just a little to keep it running. Car smokes white/bluish smoke from the tail pipes. (running rich) ( Gas smell). Changed the oil after the previous Mech worked on it smelled like gas was in it.  Did a double flush much better now.
Things i did and tested on the entire car:
Spark Plugs - New
Spark Plugs Wires - New
Battery -  New
Battery Terminals - Cleaned
Distributor cap - Cleaned and polished
Dizzy - Cleaned and polished
Pick Up - Adjusted to correct distance from roller according to 0.08in or 0.2mm
Distributor Vacuum - Good
Ignition Coil - NEW (built in resisters original ceremic resistor was missing) (https://www.holley.com/products/ignition/ignition_coils/street/super_stock/parts/8140C)
Fuel Pressure - 22-25psi in when engine is off,  while the car is running at low rpm 30psi+ ( 700 to 1k)
Smoke test - No leaks
AFM - Refurbished still sealed was installed last month
AFT Idel screw - Did not mess with
Throttle Body Screw - NO EFFECT when turning clock or counter clock
Electrical - 12V all over from Body, Engine, - All good
Ground Connectors - Clean
Coolant Temp Sensor - Ordered Arriving tomorrow (CANT IMAGINE ITS THE REASON)
Timing - Seems good 10 degrees of from original zero marking
Cylinders Compression Test - 125 + on all Cylinders
Injectors connections - look good
Injectors - listen to them with stethoscope sound health strong tick
HELP!!!?
Thank you again for reading. I will be testing tomorrow.
The coolant temperature sensor is the most likely cause, based on your symptoms.  You need to measure the resistance at Pin 13 of the ECU connector to ground to know for sure.  Installing a new one won't help if the wires aren't connected to the ECU.
I just now realized, after many years of browsing through FSM's and Fuel Injection Guides, that this drawing has the pins numbered, right in the drawing.  I never looked closely enough before.
  Installing a new one won't help if the wires aren't connected to the ECU. - Zed Head
_________________________________________________________________________
Thank you for confirming my suspitions. What do you mean if the wires are not connected to the ECU.?
Do you believe that cables broke, just dirty inside or disconnected? Should I  not even take out the coolant temperature sensor and clean it or even bother replacing it even  i have it?  Sorry for the weird question.
Edited by Cyrillink
didnot add the quote
Installing a new one won't help if the wires aren't connected to the ECU.  - reply
thank you for confirming my suspitions.
And thank you for attaching the exact connections with pins
Edited by Cyrillink
The only way to be sure that that the wires are intact from the coolant temperature sensor to the ECU is to measure resistance at the ECU plug.  If you do that you are testing the wires, the sensor, and every connection along the way.  I would not do anything to the coolant sensor, not even remove the plug at the sensor, until I measured resistance at the ECU plug.  Start at the the end, not the middle.
Hey Zed,
Tested the resistance and i was able to get a reading back, the reading was similar to when the sensor was pulled out of the car for cleaning.  Took out the plugs cleaned them to make sure everything is well.
Car did the same thing. Blue smoke, rough idle while only holding the paddle down.
Going to do another smoke test just to triple check.
2 minutes ago, Cyrillink said:
Hey Zed,
Without the actual number and knowing where it was taken, can't really tell what you're saying here.  It might the the most important measurement you can make on the EFI systems.  "a reading back" doesn't read well.
I am getting a better snapon Multi meter right now going to test it again and get back to you.
Thanks again
Edited by Cyrillink
car is indoors with the heat on to 60f
sensor reading from the ECU Harness 2.07k Ohm.
