Transmission Oil
MH77280Z
Valvoline MaxLife Synthetic Transmission Fluid - seems to be a reasonable choice. Both Orielly's and AutoZone have this as recommended. Plus it seems to cover range of applications. Unless someone has a differnet opinion.
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON(R), MERCON(R) SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
The population of Z owners with automatics is small, maybe even tiny.  I can't remember who has one but if you start a new thread with "Automatic transmission" in the title it might catch an eye.   Valvoline makes good products though, probably can't go wrong there.
