Hood Alignment Issues
BoldUlysses
On 6/22/2020 at 12:44 AM, grannyknot said:
On the door, as Patcon says, 2 locking positions, it looks like only the first is engaging. If the door seal is new you may have to slam the door to get it to close then park it out in the sun and let it get hot.  It's unheard of today to have to slam a car door, in the 70's, not uncomom, hopefully the suns heat will loosen up the seal.
The hatch, is there a possibility the captive nuts or bolts for the hatch hinges are stripping the threads or maybe some grease got between the hinge and roof flange?  A properly torqued hinge bolt should easily resist the pressure from a seal.
A lot of aftermarket door seals for the Z are to thick, I found that problem to. I have a topic somewhere with the right kind of seal for it.
  • 1 month later...
  • 1 year later...
  • Who's Online   2 Members, 0 Anonymous, 773 Guests (See full list)
