Amp meter broke
Nizodd
I'd been having problems with my ignition wire to the starter on my 73 240z burning up, i replaced the wire and checked all the connections and everything looked fine. when i had it running i heard a noise in my amp meter and the wire burned again. i have since replaced the starter since i think it may have cause the problem. is there any other reason this may have happened. also my amp meter broke and now i need a new one.
