123 Ignition plasma ball
AK260
As some have seen, I keep a log of my experiences with 123 here ...
https://zclub.net/community/index.php?threads/123-ignition-for-datsun-l6-on-my-l28.25467/
I wanted to share my latest experiences with you without duplicating that thread as I know quite a few on this forum also use / are considering 123.
In summary random missing and rough running that plagued me for months turned out to be a cap breaking down and doing a lively plasma ball impression under the bonnet. Short video below that explains what just happened ...
I will be experimenting with insulating the cap and clips with spray on insulation and clear nail polish respectively - I’m sure my wife would be delighted [emoji1787]
I am wondering if I should put the ballast resistor back in and reduce the coil voltage to avoid future antics - which does defeat the object of a flame thrower coil of course but I do wonder if the Z really does need 40kV!? [emoji848] If the spark is able to jump the 1.2mm gap then surely that’s sufficient.
What are your thoughts about ignition voltage?
The spark would have to pass through the cap material, or along the surface of the cap, to get from the electrodes to the outside.  A thin layer of nail polish is not likely to stop that.  Is there carbon tracking inside the cap?  Follow the path of the spark from the coil's center electrode, through the wire to the cap's center electrode, and then through the "button" inside and out the rotor to each spark plug electrode.  The lowest resistance path will be used by the electricity, of course.  It seems like bad cap material just based on the video.  There are conductive paths on the outside of the cap, probably on the inside too.
So Mr Z head - I did look for that but was unable to find anything really obvious. It seems like it’s going horizontally through the material from the bottom of the post inside the cap and arcing onto the clip.
What I did do was to cover the clips with heat-shrink and that took away the visible arcing you saw in the video. But engine still running less well than it should. So I suspect there is more arcing inside the cap or through material to a low resistance path somewhere.
When I was trouble shooting previously I found that when I unplugged no. 6 and no. 3 HT leads while the engine was running, there was a clicking sound from the dizzy side of the car - but no other leads made that happen. So I’m pretty sure the cap is defective on that side. New cap on order so let’s see what happens next.
Use a standard .. what is it.. 20-25 Kv  coil..  all that 123 ignition nonsense with 40+ Kv… gives you only one thing… trouble!!!…  just my 2 cents... :Zap:
Good advice chap! Thank you, will have to try it. [emoji106]
  • Who's Online   1 Member, 0 Anonymous, 950 Guests (See full list)
