February 19, 20205 yr comment_592777 A picture of a build sheet? The documentation affixed to the car as it progressed on the assembly line. They were multi-layered carbon copy paper documents with a manilla paper base stock. The paper layers were evidently torn away as the car assembly was completed at various stages. Very few examples of the base form exist. Unfortunately, my entire collection of authentic Nissan factory build documentation is on loan to Banzai Motorworks in Upper Marlboro, Maryland but Carl posted a picture here. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592777 Share on other sites More sharing options...
February 19, 20205 yr comment_592778 It is? Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592778 Share on other sites More sharing options...
February 19, 20205 yr comment_592779 After being on display in my office for umpteen years the colors, yes colors, were a bit faded. One of my customers very generously agreed to have it professionally reproduced and enhanced. Should bring the colors back. When it returns, soon I hope, I'll post the results. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592779 Share on other sites More sharing options...
February 19, 20205 yr comment_592795 On 2/18/2020 at 1:37 AM, christoffel said: A rare part that is different are the knuckle arms, They have the 12 mm ball joint shaft. Interesting comment. I believe early USA delivered vehicles had a 11 mm ball joint shaft. (Later vehicles had a larger shaft due to ball joint failure.) Keith Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592795 Share on other sites More sharing options...
February 19, 20205 yr comment_592802 1 hour ago, zed2 said: Interesting comment. I believe early USA delivered vehicles had a 11 mm ball joint shaft. (Later vehicles had a larger shaft due to ball joint failure.) Keith I have to measure, I remember 12 mm, but not 100% sure now! Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592802 Share on other sites More sharing options...
February 20, 20205 yr comment_592830 On 2/17/2020 at 1:31 PM, zspert said: Banzai Motorworks 1971 240 reproduction on a particularly nice example. 5 BTDC is laughable though. 12 to 15C initial gives way better performance. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592830 Share on other sites More sharing options...
February 20, 20205 yr comment_592832 46 minutes ago, bartsscooterservice said: 5 BTDC is laughable though. 12 to 15C initial gives way better performance. Shhhhhh! Don't let too much sunshine in on the magic. Pointing out that the "Made For USA" cars didn't have 151bhp at the flywheel when installed is like telling kids that there ain't no Sanity Clause. It's cruel. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592832 Share on other sites More sharing options...
February 21, 20205 yr comment_592883 19 hours ago, bartsscooterservice said: 5 BTDC is laughable though. 12 to 15C initial gives way better performance. I believe there were many different distributors and internal components (springs, weights, etc.). There is the so called "Euro" distributor also. Perhaps the 5 BTDC actually worked well with the US spec distributor for that car. Or, perhaps running more was better for performance. I believe the Euro spec distributor was paired with a 17 BTDC spec. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592883 Share on other sites More sharing options...
February 21, 20205 yr comment_592892 Yes, I use 10-12 BTDC @ 40 degrees dwell. I have installed Euro dists when you could still get them from Nissan US and used the same specs. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592892 Share on other sites More sharing options...
February 21, 20205 yr comment_592896 I actually set to 40 degrees and creeped along at ~ 2 to 5mph for a minute once just to see where ping occurred. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592896 Share on other sites More sharing options...
February 21, 20205 yr comment_592924 Interesting thing about those Euro dists. They were available from the Comp Dept after the standard units were NLA through the regular parts Dept. This is why I won't reuse a lock washer. Still available from your dealer Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592924 Share on other sites More sharing options...
February 22, 20205 yr comment_592957 On 2/20/2020 at 3:42 AM, bartsscooterservice said: 5 BTDC is laughable though. 12 to 15C initial gives way better performance. As the sticker says - "Vehicle Emission Control Information”- - it is not a performance spec. Customers that wanted a performance tune knew what to do. Still in several States they had to pass annual vehicle emissions tests to keep their cars registered for road use. Customers in the USA wanted cleaner air and the largest Customer Base that was almost fanatics about it was in California; where some 20,000,000 people were choking on pollution almost monthly. California lead the demand for the reduction of automotive exhaust gas pollution, with their California Air Research Board setting State Level Standards, restricting exhaust gas pollution and gasoline vapor pollution over and above the USA Federal Standards which were the strictest enforced in the world. So for daily driving a Sports/GT Customers were more than happy to give up a couple HP for cleaner air; especially in a car where losing a couple HP wouldn’t even be noticed in day to day traffic. Link to comment https://www.classiczcars.com/forums/topic/63395-mint-71-240z-more-fun-coming-to-bat/?&page=33#findComment-592957 Share on other sites More sharing options...
