January 16, 20205 yr comment_591043 It just shows the striking lever/rod being moved around in the rear case. Here's another link. https://imgur.com/a/KuNJPz0 Edited January 16, 20205 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/63420-5-speed-worn-bushing-prevents-reverse/?&page=2#findComment-591043 Share on other sites More sharing options...
January 20, 20205 yr Author comment_591174 From what I can tell it binds in reverse because of interference between shift rods. Can anyone tell from the picture if you think the striker rod is bent? It seems to have a twist at the tip where it engages the shift rods. I had to heat it up quite a bit and hammer on it to get the locking bolt off when I did the rebuild. Edited January 20, 20205 yr by Civilizedape Link to comment https://www.classiczcars.com/forums/topic/63420-5-speed-worn-bushing-prevents-reverse/?&page=2#findComment-591174 Share on other sites More sharing options...
