January 26, 20205 yr comment_591440 On 1/19/2020 at 4:00 PM, BoldUlysses said: . The hatch sill was rusted so the shop welded on a new piece. The rear lip is turned down, as shown. Is this how it's supposed to be? I can't find any close-ups online to compare. It doesn't mate with top corner of the rear finisher panels. There are also no holes for the finisher panel rivets. Any input here would be helpful also. It looks like the lip on the new sill plate is a bit longer than it should be and the lip needs to be pushed down some so the finisher can slip over top. You could take a block of wood, place it on the edge of lip and with a hammer tap the wood while moving it along the lip, it looks like you only need to move it down about an 1/8". If the paint cracks you'll have to touch that up before installing the finisher. Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-591440 Share on other sites More sharing options...
January 26, 20205 yr Author comment_591497 22 hours ago, Patcon said: Yes, you can remove the shims under the hinges. which will move it forward, but you have to be very careful the hatch lip doesn't contact the roof! It will remove the paint really quickly if it does. The hatch looks like it might still be a touch lower than the roof which will add to potential interference 10-4. Thanks for the warning. It's pretty close when opening as-is. Will be careful. 9 hours ago, 87mj said: Hopefully, this image is helpful. The hatch sill plate on this car is factory. The passenger taillight surround is installed but the piece behind the license plate is not. Please let me know if you need another angle. Thanks Yes that's very helpful! Thank you! So it looks like the lip on the end of the sill is supposed to be more like a 90° angle down. 9 hours ago, grannyknot said: It looks like the lip on the new sill plate is a bit longer than it should be and the lip needs to be pushed down some so the finisher can slip over top. You could take a block of wood, place it on the edge of lip and with a hammer tap the wood while moving it along the lip, it looks like you only need to move it down about an 1/8". If the paint cracks you'll have to touch that up before installing the finisher. Got it; I'll try that. If/when the paint cracks in the process of bending that lip a little further toward 90°, I'm glad it will be hidden by the finisher---but I've got a bottle of touchup 901 silver just in case. Thanks! Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-591497 Share on other sites More sharing options...
January 28, 20205 yr comment_591590 @BoldUlysses: What paint (manufacturer of the 901 Silver) did you go with? I tried asking for Glasurit/BASF/Limco, and they had no formula/code for it. Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-591590 Share on other sites More sharing options...
August 15, 20213 yr Author comment_626970 Update: I ended up bending the flange UP back to 180° to fit inside the finisher bend. Trying to bend it down using the block of wood technique just bent the metal above the bend, if that makes sense. I'll get it more flat, cleaned up and painted, but that ended up being my solution. Now, if only the clips that hold on the bottoms of the finisher panels weren't $30 EACH (one broke). Sigh... Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-626970 Share on other sites More sharing options...
August 15, 20213 yr comment_626980 Yikes! I forget what they look like. Where did you see them for sale? Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-626980 Share on other sites More sharing options...
August 15, 20213 yr Author comment_626981 10 minutes ago, ETI4K said: Yikes! I forget what they look like. Where did you see them for sale? Voilà: https://jdm-car-parts.com/products/rear-finisher-panel-bottom-clip-parts-for-datsun-240z-sold-individually?variant=15530867359853 $35 actually... Oof. Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-626981 Share on other sites More sharing options...
August 16, 20213 yr comment_627034 Oh yeah, now I remember. No great way to do a workaround, I guess. Mine are still buried deep in boxes, but I recall they were in good shape. Thanks for link. Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-627034 Share on other sites More sharing options...
April 8Apr 8 comment_675565 Hey guys, I'm at the final stages of a 4 year restoration and I can't get my hatch to sit low enough on the drivers side. The alignment is good, just too high. I fought and fought this, and just left it alone. But, I'm running out of things to do, so I'm back to it. I swear it fit good before I put this aftermarket weatherstrip on, but I removed the hatch. I don't know what it is. I remove the tailgate stay. Prop the hatch with a piece of wood. I loosen the drivers side bolts, loosen the left side of the right hinge a little, then barely loosen the right bolt of the right hinge, just so it stays. I can push down the left hinge a bit, but when I tighten the bolts there, it creeps back up. Am I doing this wrong? Here's the passenger side. Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-675565 Share on other sites More sharing options...
April 8Apr 8 Author comment_675567 Yeah I never was able to figure mine out. The hatch weatherstripping is pulled down off its flange in the vicinity of the driver side hinge just so the hatch sits flush. It's been a (long) while since I messed with it, but I tried adjusting every single bolt I could. Let us know if you figure something out. Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-675567 Share on other sites More sharing options...
April 8Apr 8 comment_675568 It looks like it's 2mm high. Is that is good as it gets? If it is the weatherstrip that's holding it up, why does the other side fit? Those captured nuts seem to be hitting a curved edge and when I tighten the bolts, they move up? I don't know but it's really a puzzler. I guess a guy could enlarge the holes upward on the hinge but would that even do it? Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-675568 Share on other sites More sharing options...
April 8Apr 8 comment_675570 Have a look at this post in this thread. https://www.classiczcars.com/forums/topic/55369-1971-hls30-14938-lily-build/?&page=79&_rid=2858#findComment-66409Charles mentions that his hatch lifts up as a result of the interference he describes. Edited April 8Apr 8 by inline6 Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-675570 Share on other sites More sharing options...
April 8Apr 8 comment_675571 Thank you for that. Here's a photo of the car when I got it, so I know it can be flush. There are some rub marks on the hinge, like it's hitting something down in there, "interference". I did replace the boots..... Link to comment https://www.classiczcars.com/forums/topic/63435-bodywork-issues/?&page=2#findComment-675571 Share on other sites More sharing options...
